stabilizer bar links
Old 04-17-2010 | 05:36 PM
ted's Avatar
ted
after 1.5"-2" lift on a 96-02 4runner, what have you done on the front and rear stabilizer links?
Old 04-17-2010 | 07:10 PM
trollcruiser's Avatar
I did nothing to the front with 2-1/2 to 2-3/4 inches of lift. The rear is around 4 to 4-1/2 inches. For the rear I used 2nd Gen 4Runner endlinks (1990-1995). I have had them for about 3 years and no problems and no breakage.
Old 04-17-2010 | 09:03 PM
ryani's Avatar
I bought a pair of front end links and put them on the back. Worked great! Found a set on ebay for 30 shipped
Old 04-17-2010 | 10:12 PM
yotaman85's Avatar
wabbfabb endlinks kick ass and are quick disconnects..
Old 04-17-2010 | 11:43 PM
Elton's Avatar
front nothing rear the whole sway bar got throw in a box
Old 04-20-2010 | 07:46 AM
ted's Avatar
ted
I was thinking if it will be worth the while of making an extension for the threaded portion of the link after the above said lift, objective would be to return the original tension on the bar/links thus restoring the stock handling(I just wanna feel/compare them)
Old 04-20-2010 | 10:54 AM
Midget96's Avatar
You can make your own, front and rear, using heim joints and Energy bushings, for a quarter of what those cost.
Old 04-20-2010 | 02:00 PM
crolison's Avatar
I've broken 3-4 front end links and ripped my rear swaybar off.
Yeah i think i spent 20ish on mine and had plenty of extra parts
Old 04-20-2010 | 02:05 PM
brian2sun's Avatar
Broke them and removed the front sway bar, rear's ok.
Old 04-26-2010 | 06:45 PM
Swede's Avatar
Front is OEM, tossed the rear one.
Old 04-26-2010 | 07:43 PM
waskillywabbit's Avatar
Same quality of materials and grades...sorry but no you can't.
Old 04-26-2010 | 10:51 PM
Midget96's Avatar
You don't need PTFE lined joints for a part that barely moves. Mine are all stainless metric size rod, stainless nylocks and washers. I think I spent $50 shipped for the parts to do all 4 corners from McMaster.
Old 04-26-2010 | 10:54 PM
yotaman85's Avatar
yea, because it only moves when you hit a bump or turn. not that important.
like wabb said, try making it in the same stuff for the same price.... not likely..
Old 04-26-2010 | 11:13 PM
Midget96's Avatar
I think you missed the point. End links don't move more than a few degrees. They don't move like a-arm uniball.
And in the rare instance one of these cheap joints would wear out, I could buy more than a dozen replacements and still not spend more than $120 on the whole setup.
They work just fine for me.
Old 04-26-2010 | 11:15 PM
yotaman85's Avatar
fair enough..
Old 04-27-2010 | 05:16 AM
914runner's Avatar
I broke both of the front links so I ditched the whole bar. I don't need it with the coilovers.
I have enough heims and tubing to make rear links if the stock ones ever break.
Old 04-27-2010 | 05:23 AM
ted's Avatar
ted
@midget96: thanks for the pics, I'll try to look for them parts locally here..
thanks to everybody who shared
I thought of making extension made of shaft steel (hexagon-shaped), threaded on the inside on one end, threaded like a bolt on the other end...I saw them in a 4x4MAGAZINE (Japanese)
Old 04-27-2010 | 06:45 AM
Gerdo's Avatar
Or the real answer. With a 2" lift you don't need to change anything.
Some believe that wheeling without a front bar allows the suspension to work better, me included, so people have disconnected the front swaybar.
justdifferentials
Just Differentials
06-13-2022 08:40 PM
choppe777
05-16-2016 09:00 AM
whiteyota93
09-29-2015 03:31 PM
Toys4parts
09-26-2015 02:56 PM
Pocoyota
09-08-2015 03:41 PM
