SS Brake Lines
SS Brake Lines
Hey guys,
Did a search and found the AOR SS Brake lines and then found their site but they only have a kit up to the 2nd gen. I know they work with the 3rd gens but was wondering what I need to order. I would figure it out myself but I'm in a bit of a hurry today to get everything set for my mechanic to do while I'm on a trip otherwise I'd do it myself. Anyway, here is their site. I just need to know which ones I need for my 3rd gen.
Thanks guys!
edit:
forgot link
http://www.aor4x4.com/braidedbrakelines.htm
Thanks guys!
edit:
forgot link
First go look and see if you've got banjo fittings (or not - apparently its fairly even split - no matter the year).
Decide if you want any extra length (for a lift).
Now call the phone number on the website. I don't remember if I asked why third gens weren't listed on the website. It may be due to the banjo fitting issue.
just make sure you get the right "ends" yep. I actually bought the banjo'd ones in a procomp kit when I first did my lift about 2.5 years ago but only the rear worked. so I gave the two fronts to my buddy that has a '98 taco since those are the banjo ones. you haven't extended your rear yet? The 2nd gen kit I don't know if it will work. whether it's got M/M or M/F or F/F doesn't matter since you should be able to buy gender changers with it since AOR looks like they sell them too. If it weren't colder than a witches titty I'd run down and look to see what ends are needed but...
Check out Wheelers Offroad, they sell front and rear brake Lines for Stock Height to 2.5" Lift (95.5-02 4Runners).
I really want to say my 97 cables were F (and the truck / calipers were M).
But the wheelers pic would be opposite (i'd go with the pic)
Not to drive business away, but my AOR lines aren't DOT stamped.
Well,
Its going to be my shop ordering them if I need them and I just want to have a place for them to order from if they don't have anywhere to get SS lines. So that would be the best. Also some piece of mine in knowing they are ordering the correct thing.
Originally Posted by turboale
Hey guys,
Thanks guys!
edit:
forgot link
Thanks guys!
edit:
forgot link
Really? I'd think they are about equally important? Though the rear does supply for two wheels and it has further to go, but the front disks still take most of the abuse/% of the stopping power. Is it because disks are a lot more efficient too?
Originally Posted by Bennito
would that be a gender bender?
The steel lines will give you a firm pedal and better braking with less fade. that's the reason to go braided staninless up front.
09-04-2015 10:27 AM
CanRunner
07-20-2015 02:29 PM
