Spring over axle?
Senior Member
What vehicle is it being done to. I'm sure there are differences based on the vehicle, but in general terms, the springs are re-located to the top of the axle, the knuckles are cut, turned, and welded back in place. It's generally recommended to go to a hi-steer setup.
Benefits are that you continue using the soft stock springs, which usually allow for more/easier flex than stiffer lift springs.
All 4x4 Toyota pickup trucks and 4Runners were sprung OVER axle from the factory. The only ones that were sprung UNDER are Land Cruisers.
I don't think you really HAVE to cut and turn the knuckles unless you want, but you HAVE to cut and relocate the spring perches.
Senior Member
Flying91
45
04-11-2024 04:39 PM
Jcrawl94
10
10-24-2015 04:34 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
priest16
15
08-06-2015 07:43 AM
