split cv boots
split cv boots
I just herd about some cv boots that are spit down the middle and you can just cut off your old one and wrap the new one back on and glue it shut. Ive read a little about them and have read alot about how they are not good and are really for short term fixes. Plus everything has to me very clean to apply the glue and have it work and if its not then it wont glue right and eventually fail.
Does anyone have experiences? Thoughts? where can i find some, i cant find any place that sells them yet, Thanks.
I changed mine with OEM this weekend, and the only time consuming parts were cleaning and getting the inner cv joint off. There's plenty of advice here on how to do it with the normal boots. Kragen has the split ones online (www.partsamerica.com)
I used a split boot recently for my VW that bolts together with about 8 little bolts. I would not put one on my runner. They seem weak, and I dont think they would do well with 4x4 abuse.
I ran with my inner boot wrapped in duct tape for a few months. Cheaper than a split boot.
CAP sells a "Quick Boot" I was thinking about carrying one for a quick trail fix but...(trying my best not to become a SFA snob, haha) my '85 doesn't need them. I have replaced the boot on my Tacoma, it was a PITA. Using the write up on 4x4wire to change the CV and the Haynes manual instructions to change the boot worked, but I will never do it again, way to much of a pita. Go to Autozone like someone said above, buy a new one with a lifetime warrantee, then when it rips you can say screw it and keep driving on it, then go return it for a new one. Do not pay someone to change it for you, the only specialty tool you need is a 36mm socket for the hub nut if you have ADD, and you can get that at Sears. Changing a CV is very easy.
Originally Posted by rocket
My thoughts?
Buy new complete CV axels from Auto Zone (or equal place) and get free LIFETIME replacement if or when a boot rips again.
The *new* *warranteed* axle assemblies were $66 each. Why would someone pay more than that for just boots?
Originally Posted by Flamedx4
Ditto that.
Yea thanks guys, hey Mark P ive been running duct tape on my inner for a while. Its wraped up tighter than a frogs ass right now. im not sure what im gonna do, i should and need to do it myself cause its cheap, but there is that whole 54 mm socket thing. I know a good mechanic that can do it for like 60 bucks so i dont know. Maybe when i get some $$ ill just replace both sides all new and get a warrenty with it.
Hey... Sears has the 2 1/8" socket that's easy to buy then return... I can help you if you want... I recently replaced my axles. Only prob is, the auto parts stores around here didn't have the ones I needed, so I had to order online. But, I got brand new, not remans. Anyway... if you need help just pm me.
You misunderstood. For the 86-95 you don't need to mess with the axle bearing nuts.
Thanks for the offer Keggo, ill hit u up sometime when i go wheeling im trying to plan something big in december for sure, but ill let ya know.
