!!Speedy's Supercharger Thread!!
Old 04-18-2007 | 07:09 PM
  #121
Speedy's Avatar
Originally Posted by midiwall
aye... and if they're claiming they'll warrantee it, GET IT IN WRITING!
Yep, that'd be my next step. The guy today kept focusing on the SC being warrantied with the remainder of my power train. What I need to find out is if burned valves are warrantied haha.
I'm 70% sure I'll do the install myself. Just looking at all options.
Old 04-19-2007 | 12:48 PM
  #122
Speedy's Avatar
I've been reading over the SC install instructions. For those that did it themselves, how many of you had to "clear, ie tap" the bolt locations for the dynamic belt tensioner bracket? I'm referencing page 9 step 3.
Old 04-19-2007 | 12:53 PM
  #123
mt_goat's Avatar
I seem to remember needing to do that. The last thing you want is for the bolt to bottom out on crud before it gets a clamping preload. Evidently those bolts are pretty hard to find too if you damage or break it, one guy posted up last week looking for one said he had to buy a whole new tensioner just to get the bolt that he broke.
Old 04-19-2007 | 01:11 PM
  #124
Speedy's Avatar
Ok, will look for proper tap just in case. How accessible are these bolt locations? Looks like they'd be hard to get to with a tap with the motor in the car.
Old 04-19-2007 | 01:19 PM
  #125
mt_goat's Avatar
Well I did it with the engine out of the truck, but surely there's enough room to get a tap in there without too much trouble.
Old 04-19-2007 | 01:22 PM
  #126
midiwall's Avatar
Yeah, there is... I _didn't_ do it when I first installed the SC and I had to use a couple of washers to make up the distance.
During the rebuild I did it when I put the top end back together, and the engine was already back in the truck.
Old 04-19-2007 | 01:51 PM
  #127
Speedy's Avatar
One other question. Can I re-use the stock manifold gasket per the instructions or do I need a new one?
Page 7 step 24.
Old 04-19-2007 | 01:53 PM
  #128
midiwall's Avatar
Page 7 step 24.
Yes, you can reuse it... That thing is built like a tank.
Old 04-19-2007 | 01:56 PM
  #129
Speedy's Avatar
Cool, and it is definitely a 10 x 1.25 tap right? I only question it because I've found a discrepancy or two in the instructions already contradicting themselves. If you're not sure that's fine, I'll take one of the bolts in to match it up.
Like not installing the one way valve in the IAC on 2001 and newer when later (page 11 step 1).
Old 04-19-2007 | 06:18 PM
  #130
midiwall's Avatar
dood, I dun't remember... I did what you're talking about - took the bolt and matched it up on the fly. Actually, Technically, my buddy did it.
Old 04-19-2007 | 06:32 PM
  #131
Speedy's Avatar
I'm pretty sure it's 10 x 1.25, but the threads on mine are RUSTY. I'll have to go pick up a tap if I'm gonna do this myself.
Looking it over tonight, how do you remove the fan belt? Looks like the fan has to come off first?
Old 04-19-2007 | 06:55 PM
  #132
mt_goat's Avatar
Loosen up the alternator bracket, that adjusts the tension on the drive belt, once you have enough slack in the belt it will slide off the pulley.
Old 04-19-2007 | 06:58 PM
  #133
Speedy's Avatar
So you fish it around the fan blades once it's off the pulley? I see how it will come off the pulleys, but how it can be removed? The fan "looks" a lot larger in diameter than the belt, although I guess looks can be deceiving.
Old 04-19-2007 | 07:01 PM
  #134
mt_goat's Avatar
Should be able to, at least a few blades at a time huh. I have a e-fan myself.
Old 04-19-2007 | 07:24 PM
  #135
Speedy's Avatar
By the way.....SportRunner's website is now up and running...
http://hooliganbiketech.net/sportrunner/
Old 04-19-2007 | 09:38 PM
  #136
midiwall's Avatar
Are you talking about to replace the belt with the longer one for the SC? Oh, you're gonna love this...
That belt is on the BACK of the bottom pulley. You get to take off the first two to get to the last one.
Do you have your skid plate on? Pull it off and take a look from underneath, it'll become scary clear to you.
Old 04-20-2007 | 07:06 AM
  #137
Speedy's Avatar
Yeah, that's what I'm talking about. One of the first things in the install instructions is to remove the three belts. I changed out belts on my 2.4L 4cyl once and it wasn't too bad, but I don't see how to get the belts off due to the fan. I'm hoping it will become obvious when I start removing them.
I found the bolt holes for the dynamic tensioner. I definitely need to tap at least the cast iron one. The aluminum one looks ok, but I'll run the tap down it just for good measure since I'll already be there with it. There's room, but just barely on the cast iron one if you move the wiring bracket out of the way.
Old 04-20-2007 | 07:22 AM
  #138
midiwall's Avatar
Oh, you WILL have to remove the fan... Though I guess though that Dale has a point about being able to snake the belts off, but pulling the fan is like a 10 minute job with a box end, 5 minutes if that box end ratchets. I'd pull it and save the grief.
Old 04-20-2007 | 08:10 AM
  #139
Speedy's Avatar
Ok cool. I looked in both the Haynes and Factory service manual. Neither describes how to do it to any detail. The fan just comes off with the 4-5 bolts at the front pulley no? Nothing tricky about it?
Old 04-20-2007 | 09:44 AM
  #140
mt_goat's Avatar
The only tricky part might be holding the fan still while breaking the nuts loose, so you might do that before you remove the drive belt to help hold the fan from turning. There is a slight chance the studs may decide to come out before the nuts move.
