!!Speedy's Supercharger Thread!!
Old 02-08-2010 | 08:25 AM
  #881
mastacox's Avatar
Midiwall (Mark) had a set of modified cams from Weasy2K, which he said he got some power from. How they were modified I don't know, I'm trying to find a thread about them.
https://www.yotatech.com/forums/f2/w...ew-mod-112683/
I miss that guy...
Old 02-08-2010 | 08:26 AM
  #882
mastacox's Avatar
Here's a thread I think: https://www.yotatech.com/forums/f2/3...ce-cams-44491/
Old 02-08-2010 | 08:34 AM
  #883
okie81's Avatar
I thought I read somewhere that the specialty 3.4 cams had a longer duration, but were limited in lift because of valve clearance. I'd be interested to see the specs.
Old 02-08-2010 | 08:35 AM
  #884
mt_goat's Avatar
Originally Posted by mastacox
I miss that guy...
What happened to him?
Old 02-08-2010 | 08:41 AM
  #885
Speedy's Avatar
I miss that guy...
Where'd Midiwall go?
Old 02-08-2010 | 10:08 AM
  #886
mastacox's Avatar
Suffice to say he left due to a disagreement with the management.
The site is worse off without him, his 5VZ is one of the most highly modified around, what with superchargers, cams, headers, W/MI, etc. etc.
Old 02-08-2010 | 11:13 AM
  #887
Texas_Ace's Avatar
I missed this one as well, i also think he was a great guy to have around although i have not been around much myself either.
Old 02-08-2010 | 12:37 PM
  #888
hross14's Avatar
Speedy-Et al..positive you are blowing boost out of the cylinder....
I am not talking about modified or reground cams--i am talking about:
1. Taking advantage of DOHC and dialing in Lobe seperation--basic tuning stuffs
2. For SC'ers dial in additional lobe serperation (like 114 degrees)
3. Finding the motor sweet spot and some chasis dyno time
I had a whole post but i keep timing out before i am done...
Basically, we would handle the mechanical side of the 3.4 because the electrical has pretty much been sorted out.
ERGO DIAL in the cams.....using a custom intake cam timing gear and then dealing with the scissors gear to adjust the exhaust side.....
Please, somebody tell me you know what i am talking about
Old 02-08-2010 | 12:39 PM
  #889
hross14's Avatar
And i have a set of Weasy2k cams--they work pretty well--pulls all the way to 6k rpm
Old 02-08-2010 | 01:05 PM
  #890
mastacox's Avatar
I know what you're talking about, but I just don't know that spending all that money for custom cams and dyno time will be worth it to gain 15 hp. Especailly when I've already got 300hp at the crank, and to get something like 350 all I need to W/MI and a 2.0" pulley... and maybe bigger fuel inejctors.
... or a centrifugal supercharger and intercooler
Old 02-08-2010 | 01:27 PM
  #891
hross14's Avatar
THats the beauty of it all--we dont need custom cams--or lots of money--just to figure out how to dial in the current cams we have!!
So we machine an adjustable intake GEAR--just the gear--or alter another application.... Dial in timing for said motor set-up
You would get more than 15 hp I am pretty sure. OR reduce the pulley size and still get the same HP rating via increased lobe seperation......
What we need is basically a Cam Card.
Do you get what i am saying now??
Old 02-08-2010 | 01:30 PM
  #892
hross14's Avatar
Forgot--remember the intake and exhaust lobes and center lines are not connected to one another. We could adjust them.....JUST THE GEARS WE ALREADY OWN
I think i am going to try and find me a motor.......--
Old 02-08-2010 | 01:55 PM
  #893
mastacox's Avatar
More power to you, but I don't think you'll find a huge amount of horsepower ready for the taking...
Old 02-09-2010 | 05:33 PM
  #894
shore.runner's Avatar
WOW, took me long enough to read this whole thread.
After that I have some simple questions...
Is the SC really worth it? I mean I would love more power but honestly I dont want to have to be tuning this on a laptop constantly and constantly having issues etc etc... Do you really have to spend that much time fine tuning the PSI and the afr on maps or are you guys just really hardcore
Old 02-09-2010 | 05:57 PM
  #895
Texas_Ace's Avatar
Can't speak for Speedy but in my case YES it was worth it and yes i would do it again. I have not had any issues except an exahust leak and that was not the SC fault.
The tuning takes a few days at first but then it is done and i have not had to touch mine since.
Old 02-09-2010 | 09:45 PM
  #896
mastacox's Avatar
Is the SC really worth it? I mean I would love more power...
Do the math:
Stock Horsepower- 185hp
Supercharged with properly tuned URD upgrades- 320hp
That's a 135hp increase over stock Tuning is a necessary evil, but like Texas_Ace said it's usually just when you first install, and then you don't have to do it again (sometimes tweaking here and there will happen). I've had to mess with my tune a little bit after installing a new O2 sensor calibrating system and rebuilding the heads, but this is the first time I've touched the tune in probably a year.
Overall, it is some work and you definitely have to pay to play. Just thinking you would like a little more power isn't reason enough, you have to NEED more power
Old 02-09-2010 | 11:35 PM
  #897
Do the math:
That right there was enough to get me on your side.
The thing is after reading this thread, you guys are all Engineers, and well, I would like to think i am a toyota enthusiast. I would need to get familiar with all this computer stuff. piggy back ecu's and all this nonsense... tuning is crazy
I know this has already been covered but its my understanding that the following are needed in order to have a successful supercharger experience
-TRD Supercharger kit(DUH)
-URD 7th injector kit
-Walbro 190 fuel pump
-LC-1 W afr gauge
-URD 5VZ-FE Pre Set AFR Calibrator II
-br3
-gauges to monitor.
-2.2 urd pulley
probably something else i have left out... i should be in bed
I want to just be able to tune 'er and leave it. well i know you all do too but. I like simplicity. I am not a minimalist but also do not feel the need to go insane
Old 02-10-2010 | 06:24 AM
  #898
mastacox's Avatar
I had never tuned anything before this 4Runner, it's pretty straightforward when you have a general understanding of how they work and you use Gaget's U-Tune guide.
Yup.
This comes with the URD 7th injector kit.
-LC-1 W afr gauge
Yup, for the AFR calibrator that will depend on what year 3rd gen but there are O2 sensor calibrators for either kind.
-br3
-gauges to monitor.
-2.2 urd pulley
Yup. For the gauges to monitor, really all you absolutely need is the AFR gauge. Some optional extras would be Tranny Temp (for auto), oil pressure, EGT.
That about covers it. you'll need a dual gauge pod to hold your boost gauge and AFR sensor gauge, and you'll need a laptop to tune.
Old 02-11-2010 | 02:16 PM
  #899
jrock's Avatar
one way valve dealeo...so after doing my knock sensors and putting s/c back on I forgot if this valve is on correctly..did not seem to fit so I zipd n taped it for now.
Friend of mine whom went turbo on his 3.4 says its only used for the stock injectors/stock operation as it feeds air thru the mani-injector ports etc. so he plugged that as the s/c feeds enough air...
im not so sure bot that so here I am on YT to confirm. I believe it should be installed so air coming out of throttle body goes into mani but looks like I just need a new hose or cut it so it fits better.
*sorry 4 postin on ur thread..all the s/c folks are hear!
admin can delete i reposted in new thread
Old 02-20-2010 | 02:31 PM
  #900
jrock's Avatar
so whats the best way to fab up our exhaust...sorry if your thread already covered this.
I have DT headers..I heard w/S.C's we should run 2.5" in/out of muffler. One shop told me it should be 2.5 in and 2.25 out to keep pressure.
routing?
