!!Speedy's Supercharger Thread!!
Old 07-02-2008 | 07:05 AM
  #781
Texas_Ace's Avatar
I am going to check mine when i install my SC. I need to do the valve cover seals anyways. We will see what happens if they are in ot out of spec.
I am also considering upgrading mt valve spring to the ones from sea2sky tuning. I have read that the valve springs are just not cut out for an SC and can cause float even before the redline.
What do ya'll think?
Old 07-02-2008 | 10:08 AM
  #782
spaugh's Avatar
I've done motors with shims before. Its not too bad, but being a V6 will make this one a PITA. I'll let you guys know if they were off.
You think toyota shims are a pain, try a Desmodromic valve shim system. At least the Desmo motors are only V2's instead of V6's....
I don't know about playing with the springs on the taco, mine runs like a champ with the SC. Not sure it is necessary to mod them. We aren't running that high of boost with the SC anyway and redline is only at 5500RPMs. Running a SC isn't going to make your motor rev higher. You're rev limiter will keep you below 5500RPMS therefore you springs should be designed to keep up with the motor boosted or not I would think.
Old 07-02-2008 | 10:14 AM
  #783
mt_goat's Avatar
How would you know if the valves were floating?
Old 07-02-2008 | 10:22 AM
  #784
spaugh's Avatar
You would notice a lost of power due to loss of compression if your valves were not closing completely when they were supposed to be closed.
having the spring not stiff enough to close the valve in the time it takes the rocker arm to leave the valve and come back around and start opening it again would cause them to float. This happens on very high reving motors. I doubt there is a chance of that on the 3.4L. 5500RPM is NOT a high rev limit and my truck runs solid all the way to redline.
Old 07-02-2008 | 10:52 AM
  #785
Speedy's Avatar
Wouldn't you get some backfiring and crap too?
I agree, I don't think it necessary for 5500RPM.
Old 07-02-2008 | 11:11 AM
  #786
mt_goat's Avatar
I wonder if the combustion could spread into the intake, might be scary for those running a 7th injector or spraying meth into the intake. You know how you always see those dragsters that explode halfway down the track.
Old 07-02-2008 | 12:20 PM
  #787
Texas_Ace's Avatar
Depending on which vavle was to float that could indeed happen. In fact with NOS it does happen from time to time. Nos will cause valve float due to the high pressures.
Plus my truck shifts at 5500rpm at WOT, but the rev limter is something like 6200rpm.
But if everyone else is running fine with the stock springs even with 125k miles on them then i guess i will just stick with the stockers.
Old 07-02-2008 | 01:31 PM
  #788
Speedy's Avatar
I've had my SC installed for right at a year now and no issues whatsoever. It was my daily driver for a while as well, but with gas getting so damn expensive it's become a weekend toy only as of late. I think I only drove it 200 miles total last month
I bought a 1999 Honda Accord to commute in and it sees all the miles these days. Sure does make me appreciate the 4Runner when I do drive it though.
Old 09-28-2008 | 06:58 PM
  #789
Speedy's Avatar
Finally did some video work with Project SportRunner. Lemme know what you guys think:
https://www.yotatech.com/forums/f2/l...-video-155589/
Old 10-24-2008 | 08:59 PM
  #790
Speedy's Avatar
Speedy needs your votes: 2009 Calendar
https://www.yotatech.com/forums/f121...l#post50948878
My entries on post number 77.
Old 10-24-2008 | 09:21 PM
  #791
Texas_Ace's Avatar
kinda late to ask for votes when the poll is closed lol.
Old 10-25-2008 | 07:21 AM
  #792
Speedy's Avatar
Well shoot. I've been traveling and didn't even notice it was closed already, and with only 55 votes in total too. There were about that many entries!
Old 10-25-2008 | 08:33 AM
  #793
Texas_Ace's Avatar
I have been busy as well and never even saw that thread until you linked to it.
Old 11-08-2008 | 08:48 PM
  #794
Texas_Ace's Avatar
[YOUTUBE]hvGSvHTPX3M[/YOUTUBE]
For more info you will need to hit this thread: https://www.yotatech.com/forums/f2/t...begins-146485/
Old 07-22-2009 | 11:07 AM
  #795
moebiius's Avatar
this is definitely a good read! you guys especially Speedy have done your homework! Just on a side note, I was wondering why none of you guys are using TRD 7th injectors or ecu/ecm as well....or should I say do they make them and are they any good? TRD smaller pulleys? Thanks for this post and your soon to be replies.
Old 07-22-2009 | 11:26 AM
  #796
Speedy's Avatar
Because the URD 7th injector kit is much better and tunable.
Old 01-17-2010 | 10:35 PM
  #797
spaugh's Avatar
hows your blower speedy? I have 117,000 on mine now. no problems. running redline 75w90 diff oil in my nosecone. I've been pulling a 16ft toyhauler that weighs 5000lbs over big mountain passes lately. The truck is pretty maxed out, but it seems to be holding up very well. Too bad we can't get a small diesel trucks in the US.
Old 01-18-2010 | 08:18 AM
  #798
Speedy's Avatar
No problems what so ever. Funny you asked this today, as last week I was tweaking on my tune a little bit. I haven't fooled with it in over 2 years, but decided I was bored and wanted to see if I could fatten up my 2nd gear AFR just a hair. It's tricky in this automatic trans vehicle as 1st and 2nd wind up pretty quick, then third holds for a while.
Tuning to 11.8:1 in third gear would equate to about 12.5 - 13 in second. Maybe things just happen too fast in 1st and 2nd for the 7th injector controller to keep up as I've heard others say to expect that to occur.
I did get mine to stay right around 11.8 - 12.2 in 2nd, and settled on 11.5 - 11.6 in third as a compromise.
Still loving the vehicle and it's been problem free for over 2 years supercharged. I've got about 11,000 miles on the blower now as well. I don't drive everyday anymore, so it just sees weekend fun driving now.
I drive it so little, I've actually considered selling it, but I just love it too much to let it go. I think it only saw 3,000 miles last year.
I've bought a 2009 Dodge Challenger that I've been playing with now, so it's taking most of my "hobby" time these days.
Old 01-30-2010 | 09:50 PM
  #799
Chaplain's Avatar
Speedy,
I've got a late start on this thread, but can see by the many pages that I have read that I need to go back through the ones I've missed.
My motor is on the shop floor and here is a list of the goodies in the mail:
> SC rebuilt by PSE Superchargers
> URD: 2.2 pulley, 318cc injectors, plugs, & fuel pump
> Doug Thorley Headers
> AEM Electronics fuel-ignition-controller
> AEM Electronics X-WiFi data monitor
I'm not too proud to take any advice or heads up that will help me with my install/tuning. Also, why the c/c is out is there anything I'm missing?
Old 01-31-2010 | 06:25 AM
  #800
Speedy's Avatar
Originally Posted by Chaplain
Speedy,
I'd do the timing belt and water pump while the engine is out. You didn't say how many miles were on your motor, but since it's out, I assume quite a few.
Why did you take the motor out btw?
I'd also recommend the 7th injector with AFR Calibrator HIGHLY over the bigger injectors. There are three reasons for this recommendation....
1. The 7th injector sprays fuel through the supercharger cooling the intake charge. This is important on the TRD supercharger since it is NOT intercooled.
2. The 7th injector is MUCH simpler to tune.
3. The big issue is running at 14.7:1 in boost at part throttle. The AFR calibrator which is integrated into the 7th injector controller solves that problem by richening up the mix in closed loop keeping the motor happy.
On a related note...we haven't had snow here in about 7 years so I went out to play yesterday...
http://www.youtube.com/watch?v=2bs83-Cw1RU
