Spedo Jittering?
Spedo Jittering?
I did a quick search and didn't find alot on it.
Here's my prob, I'm going down the road and my speedo is jittering like shaking erratically. I'm not hitting any bumps, at least not ones to cause this kind of jittering. I mainly notice it inbetween 45 and 75. Has anyone else had these problems? I just want to get a head start on fixing it before it gets rediculusly cold.
The cable is dry.
All '89 and up to whenever before they switched to a cableless one do this.
Mine now for the 1st few minutes during these cold mornings groans real loud.
The sound is enough to make you want to put in ear plugs.
The cure is to pull the cable out and lube it, or have the dealer replace it.
I learn to live with it.
Did someone say "speedometer cable problems?" Oh, yeah -- I've seen it all on my 2nd gen. My problems started after I put on headers -- melted through two cables before re-routing it far enough that the sheath doesn't turn to soup. The third time it happened I replaced the plastic gear going into the transfer case at the end of the speedo cable that was stripped. Did that the fourth time, too. The fifth time -- did I mention this was all in the past three months? -- we replaced the gauge cluster. It's been two weeks. No shaking, jittering, or jumping so far. Each time it failed, it had the symptoms you describe right before it failed.
It may be dry and in need of some lube, or it may be shot and ready for replacement. Or it could be a siezed up gear in the gauge cluster. My suggestion is to take action soon. Fortunately, if it does go, it doesn't prevent you from driving the vehicle. The computer will toss out a check engine light, and the O/D light wil flash on/off, but you can at least keep motoring.
Hope you have better luck than me.
Ed
Ed
I have Corey's problem as well, a LOUD screeching groan on cold days. I have to pull out the speedo and lube the cable good every winter. Should go out and do it now before it gets any colder...I'll never learn.
Needle bounces around pretty good too.
Originally Posted by Corey
I should shoot a video when I leave for work so you can see what I put up with when it is cold outside.
does it do it only when you move or when you're stopped and rev it too? mine might do it also
It can do it for 5 minutes or more, then it stops.
I will never pull it out and lube it, so I live with it.
All you have to do is pull off the outer trim piece around the guages pull a few screws and the guages fall out into your lap. The cable disconnects easily. I had to do mine twice the first time becuase I didn't work the lube in there as well as I should have. I bet if the cable were also disconnected at the TC it would pull out of the sheath a bit to make it easier. It seems like there is a seal you have to work the lube past to get it in the area that squeals and drives me nuts.
I had the rear flange come loose on the back of the transfer case which damaged the plastic gear on the speedo unit coming out the transfer, replaced it with a used one and it seems to work fine so far. First noticed the speedo shake at about 45/50mph and wouldn't really go above 65......... then the vibration started on deceleration. Dropped the driveshaft and out came the transfer oil from around the flange nut. Hopefully it didn't damage anything else?!?!?
Well my speedo still jitters but its nothing really bothering me that much. I got the squealing to go away with wd-40. I dunno how good that is. Probably isn't good but it was a quick fix because it was cold and I was just using it to get rid of the noise over the winter.
