Spark Plug Wire ?'s
Here are a couple of threads I found by using SEARCH:
https://www.yotatech.com/forums/f2/plugs-wires-75356/
https://www.yotatech.com/forums/showthread.php?t=75356
https://www.yotatech.com/forums/f2/whos-got-best-deal-going-plug-wires-50570/
There _are_ larger wires out there, but the general consensus is that when we're talking about a stock ignition setup, then a good set of stock diameter wires will give you as much kick as a cheapo set of larger wires.
Coil pack wise, yeup, you'll be fine. A larger diameter wire won't draw more current, it will only let more current flow.
montanatruck
02-26-2017 08:07 AM
88runnergomas
07-09-2015 02:12 PM
