Spark plug question
Spark plug question
Vehicle: '98 4-Runner 4-cyl.
Do I need to use the metal gasket that comes with the sparkplugs I bought?
Also the manual mentions a 16mm plug wrench/socket, do I really need to get this or will any plug socket generally work?
Thanks!
Thanks!
my plugs are 13/16ths..lol..and ONLY 13/16ths plug wrench will work...o well
you can check the gap of the plugs..i can almost gurantee you that they are already the correct gap....i always check mine just in case..and i've never found one that was wrong..lol
Are you talking about oem plugs??
Don't know about the 4 cyl engine but at least in the 5vz-fe engine, you only use dual grounded electrode spark plugs. I don't know if the 4 cyl has them or not. But now-a-days you rarely need to gap plugs. I can't remember the last time I gapped plugs.
Im Running the NGk-R BKR5EKB Dual electrode spark plugs. Gap calls for .044
http://www.amazon.com/gp/product/B00...B0KVDKP5ZZF0H3
i've tried about 10 different styles and brands of spark plugs...none seemed to be any better than the cheapo depo ones from oreiley's..so i use them..why spend a crap load on 4 name brand or whatever plugs...when u can spend just a few bucks on some cheap plugs that do the EXACT same thing...........
Pains me to say this...you are correct! Just got off the phone with NGK and he confirmed it. Looks like im putting in some new plugs today! lol
Just an FYI--the only reason Yota used the twin ground electrode was because of the wasted spark ignition system--it fires the plugs twice as much--i.e...two electrodes.
I am running iridiums--i guess just because......
