sounds like valves
Old 02-04-2007 | 11:20 PM
fatbunker's Avatar
sounds like valves
I just have a question, I have a 96 with 118k on it and I recently nothiced that when it is cold out I can hear what sounds like a valve noise at about 2500-3000 rpm. I only really drive on the freeway about 65 miles a day. I was wondering if the valves need to be adjusted on the 3.4 engine or is this common. Thanks for any help
Old 02-05-2007 | 12:01 AM
Elton's Avatar
3.4L has self adjusting vavles
Old 02-05-2007 | 12:05 AM
fatbunker's Avatar
thats what i thought, I guess i should not worry too much about it since it goes away when it warms up
Old 02-05-2007 | 04:04 AM
MTL_4runner's Avatar
If it goes away after warmup, then I wouldn't worry too much about it.The 3.4L has solid lifters and uses metal shims to set valve clearances so the shim clearances could be out a bit but adjusting them is a major PITA so I wouldn't do it myself unless it was really bad.
Old 02-05-2007 | 08:06 PM
Wife's 4runner's Avatar
Could be an injector. One of mine is making noises from time to time...
the1998sr5
15
07-14-2020 09:35 PM
JNapolitano
11-14-2019 08:46 PM
montanatruck
02-26-2017 08:07 AM
coleypull15
11-03-2015 08:41 AM
romex1
08-10-2015 07:21 PM
