Soft brake Pedal?
Soft brake Pedal?
Started with a soft brake pedal, so I checked for leaks, none. I installed new front pads, bleed the brakes worked ok, then developed a soft pedal again. So I changed the master cylinder. Sam out come, an eventual soft pedal again. Bleed it a few time with a soft pedal again. NOw bleeding seems to work for a while and then the pedal goes to the floor after 50 miles of use.
It almost seems as if the brake fluid is not getting into the master cylinder from the rreservor. Allthough I obviously use alot of fluid when I bleed the brakes.
Any Hlep?
Any Hlep?
I'm sure you probably have already done this, but check and dbl-check the tightness of the connections. Sounds like there is a slow small leak somewhere in the system. Are you losing any fluid each time you check the reservoir level?
Just a different thought, may not be useful, but I've has sports cars (old) where the brake fluid at the calipers would overheat and boil and cause soft pedal. Had to bled afterwards to get the feel back again. The same might conceivably also happen if your brake line is getting too hot from something like the exhaust. Did you recently remove a heat shield or install headers, anything like that?
If a hose "leaks a bit" it will let air in. Also a component might not leak fluid but could allow air into the system. I just spent 6 days trying to bleed a system with a defective new caliper.
I tightened up the hose from the brake fluid reservoir to the master cylinder, and bleed the brakes again. this time i did the pass rear first, like someone suggested. I pumped alot of fluid through to make sure I got all the air(especially if my leak was at the master cylinder). Brakes are firm again, they are usually better after a bleed. Now we will see if it holds. Thx for your help. Mike
94ofCanada
08-14-2015 07:37 AM
PopsDad1
07-30-2015 03:21 PM
