Should I lift my 03 Tundra?
Old 03-11-2004 | 09:40 AM
elkoholic's Avatar
Question Should I lift my 03 Tundra?
I want to lift my 03 Tundra and would like to know what problems to expect if any. I'm thinking about a 2.5" susp. and a 3" body. I'm not a "hard core" 4 wheeler but need that extra clearance for the offroading I do. No offense to anyone that has theirs lifted, but will a lift screw up my truck?undefined
Old 03-11-2004 | 10:29 AM
newheeler's Avatar
Thumbs up
Should you lift it? Absoltuley!
I'm not familar with the Tundra suspension but in general most people don't have problems with setups like that on their Tacomas. In fact that's a very common combo... You may need a front diff drop. Your truck will look a lot better with a few extra inches underneath.
Old 03-11-2004 | 10:46 AM
TDiddy's Avatar
Do you want the thread here or in the Tundra section?
Old 03-11-2004 | 11:04 AM
elkoholic's Avatar
Re: Tundra lift
I just found the tundra section. I'm a first timer here.
Old 03-11-2004 | 01:19 PM
SLC Punk's Avatar
You are asking a off-road forum if you should lift your Tundra? He!! yes you should!
3 in body lift is a little too much for my tastes. If I were to do a body lift it would be a 1in lift.
Old 03-11-2004 | 01:33 PM
fourunnabilly's Avatar
Guest
Yeah, keep the BL to the min...1" tops...get some coil spacers and/or coilovers and be creative in your application/collaberation of the two and you could get 3-3.5" easy...I have 4"+ on my 4th gen runner with 35's, all suspension lift components...just had to design the parts and have them machined.
Billy
Old 03-11-2004 | 01:39 PM
Mohamed's Avatar
Billy
Becareful though if you do go that route as earlier generations of the Tundra (2000-02) had problems of torn CV boots as a result of the clamps not strong enough for the angle at which the lift places the halfshafts. The newer ones maybe okay, but make sure to check out the boots so often in case they do decide to tear. There is a company that makes stronger boots, but forgot the name at the moment.
Old 03-11-2004 | 02:21 PM
Guest
There are boots all over the net...that will be the least of your worries...just run a search. Takes an hour or two to rip off the old ones, add some grease, and throw the new ones on...really no big deal...though still a valid one. Good luck, keep us posted on the Tundra.
Billy
justdifferentials
Just Differentials
09-08-2015 04:15 PM
justdifferentials
09-08-2015 04:13 PM
matrad
08-08-2015 04:00 PM
makemusic116
08-02-2015 06:23 PM
makemusic116
08-02-2015 05:40 AM
