Shifting problem??
Old 02-11-2004 | 08:36 PM
Dropwise Dunkle's Avatar
Shifting problem??
Sup?
I've got a problem w/ my stick shift I think. When I'm sitting @ a light in neutral and I go to shift into 1st gear, it's pretty difficult to do so. But, once I get it into gear then it's pretty east to go back into neutral and back into first. Anyone else have this happen?
1994 x-tra cab v6.
Old 02-11-2004 | 11:05 PM
EWAYota's Avatar
Check your shifters bushings, they could be causing your not-so-smooth shifting delima. heres a write up on that...http://www.off-road.com/toyota/tech/shifter/index.html
Old 02-11-2004 | 11:21 PM
Bob_98SR5's Avatar
yes. especially when its cold. but once it warms up, its fine.
im considering switching to Redline MT-90, as others have said that this MT fluid works well.
bob
Old 02-12-2004 | 12:31 AM
jimbo74's Avatar
i have the same problem... but also, when my clutch is pressed, i get a whining noise that goes away once i release it... im thinking its my TO bearing?
Old 02-12-2004 | 12:37 AM
amusement's Avatar
Yes, it's a throw out bearing. Sorry.
Old 02-12-2004 | 12:39 AM
jimbo74's Avatar
darnit, thats what i though.... how do i release it once i remove the tranny? i have been inside there before and didnt replace it as i couldnt figure out how to remove it from the forks lever.....
Old 02-12-2004 | 04:41 AM
Shifter
Thanks for that link. It's probably just what it needs, it's IS a bit sloppy too and with 146K miles, it's due.
Old 02-12-2004 | 09:03 AM
DSP's Avatar
DSP
bob
I am running Redline synthetic in all my boxes except the engine...
This morning it was -10...still had a little trouble getting it in reverse...without giving the engine a sec to warm up.
Liadrin
04-25-2022 03:54 PM
Liadrin
09-01-2015 07:44 AM
Seattle_Sign_Guy
07-12-2015 01:38 PM
crashburnoveride
07-10-2015 07:39 AM
Jnkml
07-06-2015 02:20 PM
