Sequoia rear springs on a gen3 runner
Hi, I tried to find this and I'm going to compare the rear springs from an 02 sr5 2wd v8 sequoia to my 98 oems, but if anyone has any experience or input I welcome that. Before I pull the springs. Also curious about the cv's from an 07 4wd Trd taco fitting a gen3 4Runner. Both have 27 splines and appear similar in length and diameter. Again I'm going to compare the 2 and see. Thanks in advance, I've learned so much from this and similar forums, thanks
I plan to install in near future. I'll compare them to my rough country springs then, but they look simular on truck(same #of wraps, simular width, thickness of coil wire. So I hope, but now I wait for my new5100's Then I'll start to really get at this
Left are 99 t4r Sequoia on right
Hi, so I pulled it all apart, took measurements and did a test fit. No way Jose will it fit. The top perch is 6&7/8, which is 3/8 to much. So I'm keeping rough country springs and I put 5100's on the rear, bid difference. Thanks y'all, I wish it would have worked
kawazx636
03-23-2023 09:37 AM
