Seat Brackets
So after a long over thought out process I finally have my new seats in. They are the middle row captain chairs from a Chevy minivan. I cut the feet off my old seats and welded these feet to a piece of steel bolting that to the seat. Everything is bolts and I can change out the seats to be any thing I want now. An added perk thease seats fold forward into a table with 2 drink holders built in, they also sit a little higher then the old seats and have a lot better cushion in them making it a lot more comfortable to drive. They also have built in arm rests on both sides so no more rubbing arms to fight for the little console seat.
Nice!
#25
Bracket pics?
#26
Thanks for all the compliments. It was a lot more work then I thought it would be and once I decided to just cut the feet from the old seats it was a lot easier, just have to commit to then and that is what I was having an issue with. Thanks for all the ideas and talking it out as I do not think I would have got it done without them.
The brackets where pretty easy once you cut the feet off. To cut the feet off of a stock seat was a pain as there is a rivet and then their is a spot weld that you do not see and it is harder to get through the the rivet. Used a cut of wheel and a wedge to bend the feet then bent them back into shape after I got them off. I could not use angle iron because of how they attach to the brackets and the feet so flat steel will have to do. I am not to worried because the steel I used is thicker then the steel that the feet and the brackets are made out of.
Seat bracket pics:
Seat bracket pics:
Badfish740
09-04-2015 04:21 AM
