seat bolt ripped out
happened to me to, did the same thing with washers cost me like 10$ total or something, and a lot more piece of mind because i did it to all the others too after i saw that. haha 4wheeling plus cheap seat mounts don't work well together.
#25
I attempted to fix this problem with mine several months ago, and the washers weren't big enough, they just made the hole a little larger. I tried using some wing-type washers that are spring-loaded, and they didn't last much longer.
Can anyone that has had success fixing this shed some light on how you fixed this more permanently?
If the washers are big enough to hold the bolt from ripping through the bottom side, how do you even get them through the hole?
TIA
TIA
#26
First, I used a screwdriver and a hammer to put a reference point on the floor pan; hold the screwdriver as vertical as you can through the torn out bolt hole and whack a nice dent into the floor. Underneath the truck, you'll see the dent and the spot weld marks where that raised panel holds the blind nut that tore out.
I used a hole saw and bored a hole into raised front nut mounting rail. Put a big ass washer and a nylock nut in there, fed the bolt through and tightened. Sealed it up with some silicone and a simpler metal plug easily found at Ace. Only downside is you have to remove the plug to get the seat out, but after doing that 8 months after the initial repair, I found my patch was weather tight.
#27
Seen this happen many times on here - same fix everytime.
The best thing to do, which I think somebody brought up on here, is to cut all that old metal out and weld a new piece in.
Another option would be to just get a piece of thick sheet metal that was 3-4x larger than the mounting hole and use that as a "washer."
Either way, hope that holds up for ya - may consider going around and beefing up the other bolts on your seats too.
Fink
Fink
![devil](https://www.yotatech.com/forums/images/smilies/devil.gif)
#29
#31
when this happened to me, I ziptied it with like 5 huge ones but yeah it's really not a good idea.
Cut and a weld a new piece in, you want it to hold if you get in a crash. I will have to get on this when I have welder access. better safe than sorry
#34
Just had this happen to me too... I guess after almost 201,000 miles of abuse it just gave up. Strange though; On my rig it was the right side that gave way. That's while sitting in the seat facing forward.
#35
Elton,
I had the same thing happen to me. My 99 had around 200 000 miles on it at the time. As I recall, it wasn't even a rusting issue, the bolt (and it was the on on the left), just ripped out of the floor. I am a big guy though, at 220 lbs, that might have had something to do with it!
What I did was drill a hole right through the floor and attached the seat with a carriage bolt, putting a large washer on the bottom side.
It has been like that for well over a year and I don't notice any down side to this. It should be stronger then stock, from what I can see. It is really a quick and easy fix. If you want pictures, I can send them.
Adam
Adam
Ditto mine did the same about 3 months ago. At least it cured the god awful squeaking my seat was having on rough roads. I thought it was actually in the seat back frame not the mounting holes. Oddly enough I didn't discover mine was broken until I was taking the seats out to steam clean the carpets.
jasonty
41
12-23-2018 01:00 PM
Esibnitsud
07-30-2015 08:19 PM
icentropy
07-09-2015 02:12 PM
