SEA FOAM 3.0 where to put it?
OK I have a 94 runner and want to know what is the best way to get this stuff into the engine. The PCV is too much of a pain to get at. Has anyone put this in a 3.0 can they post a pic of what vacume line they used? I am not sure where the brake booster vacume line is, that is what other posts on here say to use.
Just find ANY hose that is attached to the intake plenum and it will have vacuum while the engine is running. Make usre to pour it in slow and DO NOT drop the hose into the can for it to suck it up like someone else did. Their engine got too much at one time and hydrolocked it and threw a rod. Take your time and it will be fine. Get in a hurry and you can screw stuff up.
The brake booster is much more of a pain than the PCV valve (for me anyway), but my engine dies when I pull the PCV. I used the vacuum line for the charcoal canister, its a bit smaller, but works great.
