SCUBA's Taco is LIFTED !!!
#41
not sure exactly how many miles are on them, since I'm the second owner. I'd say 2 of them have about 70-80% left, and the other two have 60-70% left on them. If you're interested, I can send you some pics sometime. Or, just pm me if you happen to be in my area. I'm just like 1/2 hour up the 215 from Temecula.
Pm me some pics when you get the chance..
Im going to see if I can wiggle 255/85's outta my rents for my birthday, if not ill let you know..
Idk about regearing, I guess ill get the tires first and then see whats up..
4:10's currently
#44
i have the 390's with 33's and its not bad, but it would be nice to have some lower gears. plus yours is a standard cab so you should be fine.
#45
Like I said we will see
#46
Finally got the shocks in..
BLING :
I have the whole weekend off, so tomorrow ill be outside bright and early burning on the new lower shock mounts and fabbing some bumpstop extensions..
BLING :
#47
Well I got the shocks mounted up..
My saw apparently doesnt agree with the metal im trying to cut for my BS extensions..
So if the trucks gonna be ready by next weekend to wheel..Well..IDK !?!?
#48
Ok, Well original shock mounting sucked balls, Moved them up a tad..
Bumpstop extensions :
New lower Local:
How she will flex, DO NOT TRY THIS AT HOME !!!
AND ME !!!!!
Get to wheel the bitch this weekend, so well see how she'll do..
New lower Local:
AND ME !!!!!
#51
Rattlesnake Canyon / Pontiac Sluice in Big Bear.
Im going with TTORA, I honestly think the run is way full, But theres a run up to Bull Frog in Johnson Valley on the 6th, Idk if your on TTORA or not but you can find the run in the Socal section
Thanks bro.. And yea I will do that for ya, Give me like a day or 2 though
#52
#57
scuba, dangerous flex shot there. careful not to trash it before you get to play with it. couldn't help but notice the welding cart.... how about giving us a run down on what all is included in your lift (parts wise) and price and maybe how long it took you to install it. you know your fans are gunna ask it anyways. ease up on the cigs., and have a tall one on me. great job on the rig....
#58
Thats not my welder not my weld cart, My welder wasnt up for this task.
Lift components are in the sig (and it says that in post 1) but ill write them here:
Front OME 881's + N91S's
Rear: 3" all pro lift kit + upgrade to bilstein 5150 shocks. ( Lift kit includes springs, U bolt flip kit, extended brake line, lower shock mounts, stickers)
Install of rear took about 5 hours, im slow cause I work alone.
Front took 2 hours total ( I gave up with the rented spring compressors and took the struts to a shop to have them assemble)
Total price $942
I didnt know I had fans ?
That enough info for me to trade you back that tall one for your stepside bed...?
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted
Swim
9
01-04-2016 11:47 AM
Crgrey42
08-10-2015 05:23 AM
ripp96
07-31-2015 12:14 PM
