Scuba Tank
Old 10-22-2003 | 07:34 PM
loyota33's Avatar
Scuba Tank
Does anybody know if a SCUBA tank could be converted to use as an on board air compressor? How would this be achieved and how well would it work? I performed a search but didnt find any details as in set up/ capaccity, how many tires could it fill and how quickly. Thanks for any input
Old 10-22-2003 | 07:38 PM
I don't know about a SCUBA tank but I have an old R12 tank that will do about 2 tires from flat to 30PSI
Old 10-22-2003 | 07:41 PM
oly884's Avatar
Guest
it could fill quite a few tires real quick, but it's very dangerious. There is a HUGE amount of pressuer in a SCUBA tank. If that got knocked around and damaged you could be killed.
Old 10-22-2003 | 07:47 PM
loyota33's Avatar
thats a good point about being dangerous... maybe not such a good idea...
Old 10-22-2003 | 08:11 PM
midiwall's Avatar
Re: Scuba Tank
Welcome to the forum, that blinking SEARCH button towards the top of the page is your friend:
https://www.yotatech.com/forums/show...ighlight=scuba
Old 10-22-2003 | 08:22 PM
Nobody's Avatar
I have this setup....works fantastic.....I can fill 20 tires-4 from 15 to 35 psi in 10 min -its quiet and efficient- the whole setup ran approx 300...the only downfall is that most scuba shops will require a certified diving card to fill the tank for you, they dont want a amature going out and killing themselves trying to dive without certification. I extablished a relationship with a local shop that knows I only use it for airing up tires..the danger factor is there- but divers have been jostling these tanks for decades in the back of trucks/boats etc..Very few accidents have occured- the real danger is in filling -thats why its done behind a brick wall!
Old 10-22-2003 | 08:59 PM
loyota33's Avatar
NOBODY so how exactly are you set up as far as regulator, hose, fittings etc. if you dont mind sharing that is...
Old 10-22-2003 | 09:23 PM
Firefyter-Emt's Avatar
Fow way less than $300 you can also set up a much much safer C02 system with a 20lb tank and have much more air with out the high preasure.. I paid $55 for my tank, and about $75 for hoses and a regulator.. I can get it filled for just over $10 anywhere... Be safe, a scuba tank can be a missle .. You are talking 4500 psi there if I remember corectly
BTW, a 20lb Co2 tank will air up much more than just 20 tires...
Old 10-22-2003 | 10:36 PM
Nobody's Avatar
I took some pic's - I'll post em tomorrow.
Old 10-22-2003 | 11:16 PM
sick4runner's Avatar
i have friends at the local dive shop and for ten bucks the repair guy screwed a valve inflator onto my old regulator. its completely safe for the back of your car as long as its not rolling around like crazy, (its only 3000psi) a bungge or two is all the protection you need (for the extremely nurotic you can just point that valve towards you so if it blows the thing flies the other way). Its the best solution fo rsomeone with certification and a tank and reg, but to buy a tank reg and have a valve put on is a waste compared to a co2 or compressor.
Old 10-23-2003 | 02:09 AM
emptyd's Avatar
Check out this site for a cheaper/safer alternative: www.beveragefactory.com
They are also selling on eBay quite heavily.
Matt
Old 10-23-2003 | 07:16 AM
runnerboy97's Avatar
From the beverage factory, you can get a 15 lb tank and reg for about $140. then add a little extra for hoses fitting etc. that doesnt sound like a bad deal at all.
Old 10-23-2003 | 10:21 AM
Roadrunner's Avatar
I went to a local welding equipment supply shop and picked up a new 10 lbs tank for $90 and got an adjustable reg to run air tools and inflate tires.
Old 10-23-2003 | 10:35 AM
mt_goat's Avatar
Wow that's a great deal and they are aluminum tanks too. Much lighter than the steel ones. With a carry handle too.
Old 10-23-2003 | 01:17 PM
I think i am gonna have to give them a call
Old 10-23-2003 | 09:06 PM
Nobody's Avatar
Heres some more info should you decide to go this way...
Compleate setup
'first stage' regulator - outlet set at 125psi
Pony gauge reads 3000psi full 75 cf of air in tank...at 1000 psi I have approx. 5 fills left
Quick disconnects
Old 11-02-2003 | 08:56 PM
loyota33's Avatar
hey thanks alot for the info!
justdifferentials
14
06-11-2017 09:36 PM
rubrsidedwn
07-07-2016 08:28 PM
scott90
10-04-2015 10:21 AM
voiddweller
09-29-2015 12:21 AM
AlexJet
09-14-2015 10:00 AM
