Satoshi grille is on! (pics)
Location: Ocean Beach, CA Five square miles surrounded by reality.
Thanks to ASU4runner for swapping grilles with me. I did this a little different than the standard write-up. I cut the lower right and left connection points out from the grill for a cleaner look. When I cut the inside bars out of the grille, I left as much as possible on the sides, so I only needed to use bondo (no fiberglass) to fill the small gaps before I sanded and painted the inside black. And, I used zip ties to hold the mesh on, instead of twisting a bucnch of wire.
one question: is that bondo backed w/ any fiberglass? bondo is not a good filler unless it has something behind it
looks good.
i currently have the front bumper lights off my truck, the satoshi grill on my runner is ubobstructed once more and just happen to be seen again haha. i sorta missed it being open like that
Don't worry, I don't think anyone here is more of a threat to your lic. plate number than anyone off the street.
Potsy..
nice work.. Im currently on the stages of Doing this mod myself.. I have questions.. Since you cut off the 2 bottem connection tabs. how well is you frame on? I like that look.. but I dont like the idea of my grill missing 2 connection points... 2nd.. what method did you use to attach the toyota logo? and would you mind describing that in detail??
where did you place your zip ties?
i took 2 small angle pieces and drilled a hole in the middle (where it bends) for the screw. turn the angle peice upside down and the ends push against the mesh when you screw the badge in, kind of like big washer.
i used four ties on the top, drilling small holes in the mounting point parts of the grille, and then i drilled 5 holes along the bottom using the center mounting point for one of them. the way the grille curves underneath you cant see the bottom zip ties when its on the truck.
i'll take it off tomorrow and take a picture if you want...kind of hard to describe some of this without a visual
1uzRunner
63
11-10-2018 03:58 PM
Badfish740
09-04-2015 04:21 AM
