SAS'ed Taco in new Peterson's 4Wheel and Offroad Magazine
Old 11-26-2003 | 07:08 PM
Mad Chemist's Avatar
There is a sweet SAS'ed Taco in the newest Peterson's 4Wheel and Offroad Magazine, with a coilsprung front end.
Old 11-26-2003 | 07:10 PM
Cebby's Avatar
Re: SAS'ed Taco in new Peterson's 4Wheel and Offroad Magazine
And blocks under Allpro 5" leafs in the back...
Old 11-26-2003 | 07:14 PM
cruizin01's Avatar
Re: Re: SAS'ed Taco in new Peterson's 4Wheel and Offroad Magazine
Thats about smart Its usually the guys with all the money that make smart dicisions like that :pat:
Old 11-26-2003 | 07:21 PM
AznSky's Avatar
Ok I know this is a stupid question, but what exactly is a lift block?
914runner's Avatar
LMAO
Old 11-26-2003 | 07:26 PM
Nitro Hotpants's Avatar
basically its a block that goes in between the leaf pack and the axle. it provides lift. kinda the same principle as a coil spacer, but not really. hope this helps
-Casey
Old 11-26-2003 | 07:36 PM
AznSky's Avatar
Originally posted by 914runner
LMAO
what's so funny?
Old 11-26-2003 | 08:54 PM
INsr5runner's Avatar
anyone know whose it is? probably on PBB, or 4x4wire
Old 11-26-2003 | 10:03 PM
Yeah, the blocks looked pretty dumb, and not real safe. Looks like he's a Utah local, I've not seen that rig before. I don't know if they've got pics up on the magazine website, will take a look. I think he's at 14" total lift.
Old 11-26-2003 | 10:10 PM
Cebby's Avatar
The pics aren't on the site. I looked earlier.
Old 11-26-2003 | 11:01 PM
914runner's Avatar
Toyo_Runner96 i wasnt laughing at you i was laughing at what cruizin01 said about that the rich people make the ceap and stupid mistakes, sorry about that. man u must have posted just a few seconds before me, we posted at the same time!
Thanks
Old 11-27-2003 | 05:02 AM
AznSky's Avatar
Thanks
lol ok sorry, misunderstanding
Old 11-27-2003 | 10:35 AM
you guys are bashing someone for something that is not a terrible idea. the only other choice he has is to but some type of a lift spring on the rear. well if you do some serious wheeling, which alot you people on here dont, you would know that a stock spring is going to be a lower spring rate and allow for better flex. thats the precise reason i am running stock 2wd chevy leafs in the rear with a 3 inch block. i can get the lift springs no problem, but they are too stiff and dont do well on the rocks. so please dotn talk about this being a bad setup, it really isnt. yes blocks are not as safe as being attached directly to the perch, but in alot fo cases its the only option in order to acchive better flex. also the chances of the the blocks failing is very slim if you use steel and not alumiunm. and also keep up with tighting the ubolts...
Old 11-27-2003 | 02:11 PM
Stump1883's Avatar
Okay I must be out of my mind or the last person in the world to get that magazine, I suscribe to that thing and I don't have an issue w/ and SAS'd Taco in it, I would really love to know what everyone is talking about but I don't have the first clue. The last issue I got is the December one, w/ "Build it Yourself" on the cover. Is this truck in the Jan issue and I just happen to be the unlucky fool that the postman forgot. Someone let me know b/c I have always wanted to see a coil sprung SAS on a Toy.
Edit: Anyone got a shot of a rear block set-up, I've never actually seen one and have always been curious. Thanks. Also doesn't lift blocks cause axel wrap? That and the chance of them failing would be my concerns about blocks.
Old 11-27-2003 | 02:23 PM
OneTrickToy's Avatar
Lift blocks have their ups and downs. I'm running 2.5" blocks in the rear. They give a much softer ride and flex a ton, but I can't stuff my tires as far in without reverse arching my springs a bit. So there is a negative to them. Yes you do have a higher risk of axle wrap. If you find a good set of blocks, you won't have any problems of failure or slippage. My blocks have the same pinhole and pin as my leaf springs and perch, so there is no possibility of slipping. I'm not however endorsing the use of lift blocks on highly modified vehicles with high lifts. I think they are good if you have a mild lift and don't want to sacrifice flex, but when you are using those huge 5" blocks that people are using... you are asking for trouble. If you have the money.... get longer springs and weld new spring hangers. You can run much higher lifts without sacrificing articulation.
Old 11-27-2003 | 05:29 PM
Napoleon047's Avatar
14" of lift???? damn, what size tires is he running? a little too tippy for my likings.
Old 11-27-2003 | 10:01 PM
Shane's Avatar
Not all stock springs are flexy. Blocks (even steel ones) can and do fail, and also increase the potential for axle wrap and negative arch which kills springs. Lift springs can be built just as if not more flexy than any stock spring you can find.
IMO, they are a cheap way to get lift now while you save up for a real solution.
Old 11-28-2003 | 05:17 AM
Cebby's Avatar
Hold tight. It just came out. It is the January issue that has the SAS Taco. It has 39.5" tires.
EDITED FOR CONTENT: I am not
Old 11-28-2003 | 05:25 AM
Stump1883's Avatar
Sweet, thanks Cebby, I hope the mail man brings me a present today, or early next week.
Old 11-28-2003 | 07:29 AM
I love it when newbies come storming in here like someone just whizzed in their bowl of wheaties.
