Saggy Rear
Saggy Rear
See how the back of my truck sags to be lower than the frount. What would be the cheapest/best way to raise it up enough to make it level?
Check out this post and you can weigh your options:
https://www.yotatech.com/forums/f2/beginners-guide-lifting-your-tacoma-27391/
I'm having the same problem with my 1990 ext cab 4x4 pickup.
Regarding shackles,add-a-leafs...how hard is labor on these? how much will labor cost on these?
On another thought, if i was to install a body lift, can i just double up on the blocks in the rear?
Stay away from the blocks. Bad idea - check out the previous link I posted. There is an article available on the types of lifts for p/ups and the pros and cons of them.
Originally Posted by Paul H.
My 2wd Nissan's rear is sagging too but the leaf springs are under the axel. What is the best way to level or lift this setup?
I posted earlier about springs on a diff thread. I replaced my stock springs on my 92 with stock aftermarket springs,measured before and after.......raised it 2 1/2".Previousley I added 1.1/2" shackles paid $50 for them but had to torch out old rear bushings which added another $15.
hey s4m,
i don't think your truck is saggin that much...hte pickups form 89-95 have a lower fender well in the rear...if you look at your body line down your box and door you can see this...i think you should only fix this is you want more Rake on your truck..but its up to you
cody
cody
kirkrunner
07-27-2015 07:59 PM
Athansinis
07-27-2015 08:38 AM
icentropy
07-14-2015 10:23 AM
