S/C + auto tranny + ect
Old 01-28-2005 | 09:00 AM
metalhed's Avatar
Greetings I am thinking about having the A/T in my S/C truck worked on, going with a similar setup to the Level 10, and I had a question about the use of the ECT switch.
Does the tranny upgrade/rework effect the ECT? If the shop ( www.atsdiesel.com ) tightens the shifts up and improves fluid flow and cooling, does this make the ECT a moot point?
It is my understanding that the ECT moves the shift points up and supposedly shortens the shift time overall. But if the tranny is upgraded and does this as a now normal thing, what becomes of the ECT.
I dont use the ECT currently as it gave me less MPG.
And if an improved tranny is subjected to the ECT what does it do? thanks
Old 01-28-2005 | 11:37 AM
4-RUNNIN' FREAK's Avatar
Still works fine in mine. Had mine done by IPT.
Old 01-29-2005 | 08:36 AM
TRDOLMAN's Avatar
I hope for your sake that ATS knows what they are doing with your tranny. You might want to consider letting John at www.importperformancetrans.com do the valve body for you.
Dave
Old 01-29-2005 | 09:31 AM
MTL_4runner's Avatar
I have to say ditto on just sending the valve body to IPT, he has done many of these and gives great service (fast turnaround) at great prices.
Old 01-29-2005 | 10:57 PM
88FJ62-Cruiser's Avatar
Dave
ats has done some upgrades on the towrig for a guy on pirate ( a write up was done) i dont think youd go wrong with the,
Old 01-30-2005 | 07:09 PM
metalhed's Avatar
I am 100% sure of ATS and their abilities. They are a sponsor of one of our race serices at the track I work at, I see the stuff they build and the customers they serve and have no problem letting them work on my truck.
The question I had was, if the tranny is tuned and shifts harder not using the ECT, what happens when you use the ECT? Does the shift point get moved or is the ECT rpm driven , does it interface with the 'puter on shift points. Does the tranny upgrade make the ECT obsolete. thanks
Old 01-31-2005 | 05:55 AM
TRDOLMAN's Avatar
My ECT works the same as it did before the VB upgrade.
Dave
hawks7106
Diesel Swaps
05-16-2016 06:44 PM
tinigunner11
08-14-2015 02:19 PM
Iceman4193
07-15-2015 05:48 PM
