runner key problem
runner key problem
my dad called me today and said he can't start the runner...specifically that the key won't turn. he said lately when he starts it using his spare key (which is rarely used) is gives him a hard time, but will usually turn after a few tries, with some force. but when he uses my key (which is used daily) it usally turns must easier. then today he goes and tries his spare key, cause that's the one he has on his key ring, and it just would not turn. then he tries my key, and that didn't work either.
so he calls the local toyota dealer and they say the weight of the keys on my keychain has messed up the tumblers for the key and they need to have it for a day to fix it.
now i've never had this problem. the worst i've had it is like once a month it wouldn't turn but then i just adjust the steering wheel a little, give it some force and it turns. my runner has been at home for about a month now, only being started and driven maybe once a week by my dad, and he says it's giving him all this trouble.
anyone heard of excessive weight on a keychain causing the tumblers to get out of order. i only have like 3 or 4 keys on my keychain, doesn't seem likely that's it. i did a search and didn't find anything exactly like this, but i did see that a lubricant might be the remedy for the key not turning...
Re: runner key problem
I have heard this before, but I also drive a service truck and have a nice heavy brass spring loaded rope clip for my belt clip, and lots of master lock keys, lots of commercial keys for mechanical rooms and such. needless to say, its heavy, but never had a problem wearing out a cylinder.
Try some graphite powder, don't spray anything 'wet' in there. That only attracts dirt and gunk to further exasperate the problem.
Yeah, I would try spraying something in there first. You can use the graphite power or they make little aerosol spray cans with lock lubricant just for this purpose. I used it on mine when my ignition stuck and it freed it right up.
Good Luck
Good Luck
thanks for the tips guys. my dad used some graphite and that seemed to do the trick, works just fine now. if it happens again, i'll suggest the lock lubricant.
Charles,
Sounds like the dealership answer we hear all too often.
Something needs lube.... Replace it with a brand new, expensive part.
BTW... I have been meaning to ask, what up with the newish gothic avitar??
Originally posted by SkyRat
Charles,
Charles,
oh this avatar isn't meant to be gothic, it's just the symbol for a band i like, alkaline trio.
i had similar trouble with my 93's key. wouldn't turn, needed to fiddle with it to get it to work. had a few sketchy situations where i thought i was screwed.
the stealership started feeding me a line about the tumblers being out of whack, needing to replace the whole unit, etc. ...
i urged them to cut a new key from the records. they did, and that still didn't work. then, i looked at the key closer and was like, "this can't be the same key template, the key shaft is way too thick."
they cut another one and -- voila! -- turns like a charm.
haven't had any trouble since.
voiddweller
19
05-02-2016 09:10 PM
alfonz33
9
11-16-2015 09:21 AM
