Routine Maintaince while intake off??
I'm about to tear in to a spark plug and wire change. I'm also going to clean the throttle body and MAF while I have them apart and also do the deck plate mod along with a new tru flow filter. My question is.....What else should I replace or check while I have all the intake piping off? Any suggestions?
Your title hits like you were taking the whole intake manifold off....that's a whole different ballgame.
It sounds like you've got your bases covered though in terms of general maintainence; MAF & TB clean is always a good idea.
(Am I ready for baseball season for what?! )
i did this recently, minus the spark plug wires and deck plate mod. and i noticed a better ride, better start up and a little better gas mileage. spark plug changing is a PITA, make sure u got everything b4 u start working
when doing MAF sensor and TB cleaning, make sure u got towels to catch the TB cleaning run off. i used a tall step lader, to stand on while removing the spark plugs. and a pack of marborol lights
and as far as deckplate i did some reasearch b4 i did it, i still havnt done it but ive been reading this:
https://www.yotatech.com/forums/f2/d...othing-186443/
as far as the gap settings, i dont remember but ask the people where you bought them if they were pre-gapped, they should of been, well at least mine were
I have some anti-seize from work. The copper hi temp kind. That should do the trick. Hopefully it warms up a bit. the lows for tonight is going to be 25 below. I'll have to run the furnace in the garage for a long time before my fingers will be warm. HaHa.
Thanks everybody for all the info. It will make the project go alot easier.
might not want to do it in the garage, especially when u are using the MAF sensor spray and the TB spray, the lighting might not be enough for you also, unless it is really bright in there.
where do you live? seems everywhere is getting that cold artic blast
kawazx636
10-06-2021 04:03 PM
LittleUgly
15
01-02-2020 02:30 PM
