roof rack?
roof rack?
im looking at a thule roof rack basket systema dn im wondering if you had to buy the cross bars to install it or did you u-bolt it directly to you factory rack....2000 4runner.
my buddy can get it half off and i want to order one soon. so what install did you guys do to make this work? And will it stillaccept bikes?
thanks
thanks
Re: roof rack?
thanks
thanks
Hope this helps!
Brian
Senior Member
Most thule stuff is setup to mount to either Thule bars or factory bars... I suspect (but don't know for sure) that the baskets will too. The down side to mounting to the factory crossbars is that they are not as sturdy as the Thule bars. This may or may not be an issue for you depending on what you plan on using the basket for.
Thule's can be mounted either way depending on which setup you select. The Playpen (basket) mounted to the Thule load bars has a higher weight capacity and sits a little higher off the roof deck. Mounting to the OEM cross bars won't be a sturdy, as jacksonpt said, but is a bit cheaper.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Scotttekoch
09-28-2015 10:30 PM
