RF window stopped working today, I could use some help.
I drove to work this morning and it worked fine, no problems. When I left work, the passenger window would not respond to either the passenger door switch or the drivers door master switch. All the other windows work fine. There seems to be power at the switches on the blue/red wire. So I assume its getting power. Do these window motors die instantaneously? What else should I look at? Motor, relay, ...
My 02 corolla did this same thing worked when cold but not in the heat. Replaced the motors and it fixed it. I would pull the door panel and jumper the motor before you replace them though they are expensive
WTB[FourCorners]: 84-88 Toyota Pickup Doors with Auto Windows
subaruwrx88011
10-09-2015 01:39 PM
