Retorquing bolts as routine maintainance
Old 11-17-2006 | 05:46 AM
Greenman's Avatar
I was just looking at the service intervals for my '98 Tacoma 4x4 at http://smg.toyotapartsandservice.com...1998&int_id=68
There's something there that I don't recognize. It says "Lubricate propeller shaft and retorque bolts (4WD)"
It just occured to me that propell is a synonym for drive -> propeller shaft = drive shaft. I'm in the habit of doing the standard chasis lube whenever I change my oil, so I've got that covered. But which bolts need to be retorqued?
Thanks,
Greenman
Note: I unintentionally posted this question first to the non-year related forum. Since routine maintainance does vary, I've reposted it here with appologies for double posting.
Old 11-17-2006 | 06:47 AM
neoworm0's Avatar
I would assume they are talking about the 4 bolts that connect the shaft to the t-case and the four that connect it to the diff. Not a bad idea I suppose but I can't say I ever retorque mine Unless I remove it for some reason.
Old 11-17-2006 | 07:48 AM
eric-the-red's Avatar
It doesn't hurt to check those bolts while you're under the truck, they have been known to come loose. Just stick a wrench on them and make sure they're still tight.
Corvoid
09-14-2015 11:10 AM
Pocoyota
09-08-2015 03:41 PM
Jwp1
09-06-2015 12:03 PM
eggens
09-05-2015 01:16 AM
Aaron Logan
09-03-2015 09:08 AM
