Remote programming problem
Hello,
Have a 2000 4runner SR5 and one of the two original Toyota remotes broke, so I purchased a new one online thinking I could program easily...unfortunately not the case!
I have searched this site and found the correct remote programming instructions...driver door open, 5x door locks, door close/reopen, 5x door locks again, insert key on/off/out...then I should get some type of acknowledgment from the door locks but that never happens. Have tried this maybe a dozen times but can't seem to get into the programming mode.
I purchased the vehicle off a lease so not exactly sure what's installed. I know that an Audiovox Pursuit PRO 9232 upgrade module was installed at some point. There is a small red led light on the dash just to the right of the dash dimmer knob that blinks when the alarm in on.
I have no idea why it won't go into the program sequence. I do know that once I start the door lock/unlock part of the procedure, the alarm chirps and the LED dash light starts to blink (I cannot seem to get around that happening).
I've triple checked the procedure and it also matches the procedure sent to me where I purchased the remote. Any idea what I might be doing wrong? I really don't want to take to Toyota for help and pay $$ if I don't need to.
Thank you, Jon
Thank you, Jon
theking11863
03-19-2016 10:36 PM
Esibnitsud
07-30-2015 09:21 PM
