remote keyless entry not working
Just picked up a 99 4runner came with 2 sets of keys both with remotes, but they don't work at all. The remote unit has 3 buttons; 1 for doors, 1 that has a '*' (asterix), and 1 for the rear window/door. The red light on the remotes come on -batteries are good. Where do I begin to troubleshoot this?
Change the batteries... Just because the lights come on doesn't mean it has enough juice to function properly.
An overhead crane in the uranium mill I work in quit working. The lights on the remote came on so no one checked the batteries. $200,000 was spent flying a company from the states up to test and overhaul it. Batteries were bad in the remote, $8 problem.
Might not be your problem but it's worth trying before you spend more.
If that's not it for sure maybe try finding out how to reprogram them. If theres no way for you to a good locksmith MIGHT be able to help if not I'm sure the dealership will gladly take your money.
Sounds like an aftermarket RKE/Alarm unit. The Toyota factory remotes have a Lock and Unlock button and no LED. Most also have a rear window DOWN button and a red "panic button" on the back.
I'd look under the seats and under the dash for a control unit to see if you can identify the remote unit. If you can identify if it's an aftermarket unit and which exact model then you can probably find some specific troubleshooting info.
Like Apache said, check the battery. Also posting a pic of the remote may help too.
I'm pretty sure the 4runner factory keyless entry is part of one of the ECUs. The dealer added option unit probably has a separate ECU that's added at the dealer.
Yea,Tear that old alarm out,along with the wiring...and hope they didn't butcher up your wiring harness....Very few aftermarket alarm's stand the test of time..Can/will cause intermittant problems in future...even if the remote does not work....
I hope its not a "gulf states Toyota" alarm/keyless entry..a friend of mine had massive problems with his..untill he ripped it completely out,wires and everything...
ashersullivan88yota
01-18-2022 06:37 PM
09-04-2015 10:27 AM
crashburnoveride
07-10-2015 07:39 AM
madxman21
07-09-2015 11:26 AM
