Regarding warping rotors...
Guest
I was bored and went to http://carreview.com/SUV/Toyota/PRD_48_1524crx.aspx.
The very last guy to post, writes:
What is that all about?
One major problem was front end wobble under breaking. Thought it was warped rotors, but it turned out that there was a service bulletin out on this and a kit to fix it.
"I am sorry to report that the 03 4Runner V6 is a clunker. After 12000 miles, all wheel drive gave out, had to replace it. Still not working right after it was replaced. The engine won't run if the temperature is below minus 10, and I have it in the shop over 5 times for other complaints"
hahahah
something's fishy here.
hahahah
Location: Far western Kentucky (transplanted from central PA)
I don't have the info in front of me, but there is a TSB for specific, late model 4Runners which is related to the problem you described. If I recall, the dealership replaced my rotors as part of the TSB fix. I still had to replace my rotors 2 years later, though. Do a search and you'll find a lot of info on warped rotors. A lot of forum members have replaced their warped Toyota rotors with other brands.
Guest
So we have confirmation on the service bulletin Atlantis might not be lost after all.
Will the infinite collective wisdom of yotatech produce further details or even a link?
Originally Posted by Rick F.
TSB BR007-00 "Front Brake Vibration, '96-'00 4Runners"
hmm 03 4 runners are bad? my mom has a 03 4 runner v6 with 28,000 miles on it and no problems what so ever..... we plan to get another 100,000 on it too. i would check out that lemon law if i were you.
_Nicco_
09-21-2015 03:06 PM
