recomendations for 1"suspensio lift on '94 4x4 xtracab?
anybody know of a great way to lift my stock 4x about an inch? would adding some bilsteins alone lift the truck an half inch? thanx!
Hello and welcome to the forum.
This post here should be of help to you.
If you just want to go up an inch, crank up the T bars up front a tad (Search for that topic here, as there are links in it to do it) and you can put a shackle in the rear or add a leafs to bring it up.
No shock on the market other than an air shock can raise you.
Shocks are only a dampening device and provide zero lift.
Also if you raise, it's a good idea to make sure you have manual hubs up front instead of the ADD system where they are locked in all the time.
The ADD setup puts stress on your CV boots and shafts if you raise it.
09-04-2015 10:27 AM
whereAreMyPants
07-22-2015 04:32 AM
MTLroadierunner
07-20-2015 04:07 PM
