Rebuild advice...
Old 08-26-2004 | 09:41 AM
TRunner's Avatar
Question Rebuild advice...
Where I'm at now:
I have the block assembled up to the EFI but no EFI on yet. Sparkplugs, injectors, heads, oil cooler, oil filter, oil pan are all on and it is in the truck. I have the starter on also.
I would like to know what you guys think about hooking up the battery and throwing in the oil to go ahead and crank it now to make sure the starter is hooked up right and test for oil leaks before I finish the full install. Also check for any funny noises. Is it ok to do?
Old 08-26-2004 | 11:31 AM
TRunner's Avatar
<bump>
Old 08-26-2004 | 01:39 PM
TRunner's Avatar
<bump again>
come on guys! I am about an hour away from getting started on doing this...
Old 08-26-2004 | 01:52 PM
EWAYota's Avatar
Bump!
Old 08-26-2004 | 07:51 PM
4Hummer's Avatar
Your just gonna crank it over and not start it right ?? You should okay. Dont dry crank it... Put some oil into the pistons...
ANYONE ELSE ???
Bump Bump
Oh and HEY
Old 08-26-2004 | 07:59 PM
gwhayduke's Avatar
If you oil the pistons, be sure to leave the spark plugs out. It would be a shame to break a piston.
Old 08-27-2004 | 07:13 AM
TRunner's Avatar
I put in 5 quarts of Mobil 1 and turned it last night. No funny sounds and no leaks. I did have the plugs in though... Why would that be bad? I know gwhayduke said I could hurt a piston, but all sounded and went ok.
All I have is some of the engine on the stand...
Old 08-27-2004 | 04:11 PM
gwhayduke's Avatar
If you had put too much oil in the cylinders, installed the plugs, then turned it over, you run the risk of hydrolocking the engine. It sounds like you're ok!
Old 08-29-2004 | 06:52 PM
TRunner's Avatar
Gotcha, but...
Up and running as of about a couple hours ago!!
Old 08-29-2004 | 07:55 PM
gwhayduke's Avatar
Is that Ford blue on the pulleys?
Old 08-30-2004 | 06:37 AM
TRunner's Avatar
Good God, man! I might as well drop a Ford engine in it if I were to do that! That is all powder coated, actually. I'm not sure of the name of the color but is a rather electric blue.
Dale Johnston
11
10-31-2015 11:22 PM
the_supernerd
10-01-2015 10:20 PM
ktm192k
10-01-2015 09:47 AM
tylermx71
09-29-2015 09:49 PM
voiddweller
09-29-2015 12:21 AM
