rear wheel cylinder
Old 08-04-2004 | 04:55 PM
neutronsr5's Avatar
rear wheel cylinder
Hey,
just wanted to make sure this is normal. I'm trying to see what is wrong with my e-brake and rear brakes.
I jacked the car up removed drums (which was a b*ch to remove). When I press the brake with engine on the wheel cylinders spit fluid non-stop as I hold the brake down. Then I hear a beep. I figure the wheel cylinders are blown and need replacement. But is that beep normal?
Old 08-05-2004 | 09:39 AM
Flamedx4's Avatar
Can't tell you what that beep may be, but wheel cylinders should not spit anything, ever.
Old 08-05-2004 | 09:43 AM
seaflea's Avatar
Sounds like youre wheel cylinders are bad.
The beep may be from the pedal getting too close to the floor I.E. brake warning beep. Just a guess
06-01-2021 02:51 PM
jerusry
10-19-2015 06:28 PM
87turboPA
07-12-2015 08:49 AM
cars-guy
07-11-2015 08:51 PM
87turboPA
07-09-2015 06:58 AM
