Rear tire locking up
Old 01-04-2007 | 05:20 PM
my86yota's Avatar
I have a 96 runner and recently the rear drivers side tire has been locking up on the snow. It only does it when it is cold or where I haven't driven it in a while. We replaced the wheel cylinder and did a break flush. It seemed to be a little better but it still locks up. The only way that I have found to get the tire loose is to put it into reverse. What do you guys think I should check next?
Old 01-04-2007 | 05:53 PM
rimpainter.com's Avatar
Is the axle seal leaking? Are the rear brakes adjusted properly?
Old 01-04-2007 | 06:19 PM
my86yota's Avatar
The axle seal was replaced back in August. As for the breaks being adjusted, I adjusted them to where they wern't rubbing on the drums.
Old 01-04-2007 | 06:21 PM
CJM's Avatar
CJM
Should be .05 to 1mm from the drum..
Old 01-04-2007 | 06:23 PM
keithguts's Avatar
Maby your Adjuster is froze up
Old 01-04-2007 | 06:25 PM
my86yota's Avatar
How do I know if it is .05 to 1mm from the drum?
I was driving it around for a while today and it was getting a little bit warmer then the passenger side.
Old 01-04-2007 | 06:27 PM
my86yota's Avatar
Is this common? Should I go ahead and replace the adjuster?
Old 01-04-2007 | 06:32 PM
CJM's Avatar
CJM
Easy to adjust as the brakes are self adjusting actually. While going in reverse pull the emergency brake back slowly till it clicks about 15-17 times..this will automatically adjust them.
Old 01-04-2007 | 06:40 PM
my86yota's Avatar
Thanks, I will go and give it a try and see if that does the trick.
Old 01-04-2007 | 06:54 PM
Keep in mind that this "trick" didn't work for me. Mine were so far out after I changed the axle seals and shoes that I had to use the star adjuster method. Personally, I find the star adjuster method easy. Jack up the vehicle via the axle, spin a wheel, adjust the star wheel until the wheel only spins about 1/2 way around with a moderate spin. I don't know, that worked best for me.
Old 01-04-2007 | 07:00 PM
CJM's Avatar
CJM
To clarify this only works if the drums are close to adjustment andnot off by much, the star wheel method is what I would use if I didnthave adjusted them yet.
Old 01-04-2007 | 07:15 PM
my86yota's Avatar
Ok I went out and tryed pulling up on the E break a few times and I think it tightened it up a little but I don't know if that is just because the breaks are warmer now then in the cold morning. So I will try it again in the morning and see if it is better.
What is this Star adjustment method that you guys are talking about?
Old 01-04-2007 | 07:52 PM
See attached (FSM pdf)
Old 01-05-2007 | 10:41 AM
my86yota's Avatar
Ok I readjusted everything. I went out and tryed it in the cold morning and it was still draging. I don't know why it only locks up when it is cold and I haven't driven it in a while. Would the breaks lock up in cold weather if they were not adjusted properely?
Old 01-05-2007 | 10:49 AM
Gerdo's Avatar
You said that you replaced the axle seal. Was it leaking? Did you replace the Lube soaked shoes? Lube soaked shoes will be more grabby on the drum.
Old 01-05-2007 | 11:43 AM
NPE701's Avatar
I had exactly the same problem with my '98. Right rear wheel would stay locked, especially on snow/ice. After a while I found out that either the e-brake cable or lever was sticking because of rust and mud and what not in there.
Old 01-05-2007 | 02:50 PM
my86yota's Avatar
When I had the axle seal done it was leaking at the time. I only replaced the wheel cyclinder, I left the shoes alone.
Old 01-05-2007 | 02:52 PM
my86yota's Avatar
How did you go about fixing it on your 98?
Old 01-05-2007 | 04:57 PM
There is a lever mechanism on the passenger side. It needs to freely move back and forth as the e-brake is pulled. If it gets rusted, it can cause one side to stick. Check that out. You can't miss it.
Old 01-05-2007 | 09:44 PM
tom_mag's Avatar
If the surface of the shoes is contaminated it will screw up the coefficent of friction and could cause it to lock up. Also if it is not adusted tight enough it could lock up in the cold due to to much clearance. You want the shoes to rub against the drum a little.
Think of it this way: Imagine I tied a rope around your waist and told you to run, and eventually I was going to pull the rope to make you stop. Would you want me to leave the rope slack, or pull tension on the rope?
If their is a gap between the shoe and the drum (the rope is slack) when you stop it will jerk to a stop and lock up. If their is drag (tension on the rope) it will stop smoothly. When it is really cold the metal doesn't expand as much and increases the gap between the shoe and the drum.
I would replace the shoes if they came in contact with axle or brake fluid. After that I would tighten the brakes on that wheel.
