rear diff drive shaft and axle seal ??s
ok so i have 02 4runner at about 76k (details in sig) but anyways, the driveshaft has an inch ro so that it has moved, appears recent(shiny w some oil) normal flexing or problem??
next....the differential appears like it has recently had fluid on it (appers wet you know??) so is this bad?? what would need to be fixed??
axle seals....ya the picture i looked at...mine look haggard, so does like wet looking junk on them mean bad seals??
also after the cats and there is the place where the pipe bolts to where the muffler pipe starts, on the heat shield above there is black looks like spray what could my prob be???
idk what to do so any input would be good....and fast plz don't want to ruin somethin i could have fixed instead of driving and breaking
I assume you are talking about the grease that gets slung off of the u-joint on the driveshaft when the driveshaft turns. If so, it's normal and it'll happen everytime you grease the driveshaft. Post a pic if you're unsure of whether that's it or not.
GSGALLANT got you covered. Take some pictures if you can. Upload them to Photobucket or another server, and then link them in your reply.
AustinTaco
06-21-2015 09:54 AM
