Rear Coil Spacer.
Old 11-14-2002, 04:42 PM
Brad's Avatar
Question Rear Coil Spacer.
Are rear coil spacers for 2nd gens good? Will I need longer shocks. I am just curious. Probably going to go with 1.5" Downey springs instead.
Old 11-15-2002, 10:36 AM
Beowulf's Avatar
Re: Rear Coil Spacer.
You are right, if I were you I would go with Downey Coils. IMO they would perform better than spacers.
Old 11-15-2002, 10:42 AM
Co-Founder/Administrator
Staff
Corey's Avatar
If you go with the Downey HD coils like I have, they will net you around 2" or so in the rear.
Stock length shocks will be fine.
You don't need the longer shocks until you start adding the 1.5" spacer to the Downey coils, and that is not really needed unless you plan on running 33" or bigger tires.
You can run 32" tires with the Downey HD's, and a T bar crank.
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
terminator
07-27-2015 07:13 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Rear Coil Spacer.
