rear axel seal i think?
Old 12-17-2004, 10:53 PM
keisur's Avatar
yea, I saw that later. for the inner I use the $6 harbor freight seal driver kit to pound it in. it's got a disc a hair smaller OD than the seal that works perfect. the outer is just a paind because of all the press work.
20 minutes is pushing it though. you gotta undo the 4 nuts, undo the brake line, undo the ebrake cable. pull axle. pull old seal. pound in new seal. put axle back in, torque all nutz, hookup brake line, hook up ebrake cable, bleed brake. it's alot more than 20 minutes of work.
I also forgot to mention to go ahead and grab a new oring for the housing/flange mate. the old one will be triangular and won't do very well anymore and is only a few bucks at the stealer and should be replaced anyway.
Old 12-17-2004, 11:30 PM
AW1090's Avatar
yep, longer than 20 min for sure...I forgot about the o ring. I tried using the 54mm socket as mentioned somewhere and it worked pretty well you just have to have it straight on or it will bend the seal. I'll have to check harbor for that driver kit
Old 12-18-2004, 12:18 AM
keisur's Avatar
thats why I didn't use the 54mm socket the second time,. hehe.
Old 12-18-2004, 12:24 PM
Ironmike4x4's Avatar
Originally Posted by keisur
you didn't tell me that you sack! Now I know who's gonna get me parts from now on since you're local, hehe.
He he, yeah I can get GM parts at cost, unfortunately Toyota wont do the same for us
Old 12-18-2004, 06:42 PM
  #25
swimmer's Avatar
I used a 2" (I think) piece of PVC pipe to pound the seal in when I did it. I worked pretty well. Cna be tricky seal to put in though without a press.
Old 12-19-2004, 05:48 PM
  #26
keisur's Avatar
you don't use a press to put the seal in.
Old 12-27-2004, 06:34 PM
  #27
jtm994's Avatar
i had the axel seal replaced and it is still leakin. can someone post a pic of where the diff breather is? thanks
Old 12-27-2004, 08:09 PM
  #28
AW1090's Avatar
Where did you have the work done? If it were me I'd take it back and have them do it again....it's an easy job to screw up. If they rested your axle on that seal as they slid it back in then that can screw up the seal all by it's self.
Old 12-27-2004, 08:11 PM
  #29
AW1090's Avatar
sorry...I also meant to say that I think the breather is on the top left of the rear diff if you're standing behind the truck, but I'm telling you the mech that did the work probably messed it up.
Old 12-28-2004, 09:23 AM
  #30
keisur's Avatar
just crawl under the rear and look on top of the axle housing for an aluminum colored pud looking thing sticking out of it about .5-1". Or look in the Tech Section of YT and there are pics posted there.
Old 12-28-2004, 09:27 PM
  #31
travelinman's Avatar
I had the same thing happen on my '90 4runner. It sucked. I didn't bother with doing it myself. I cost me something like $450 to get the job done at a local place in Boulder. I'm somewhat mechanical, but the pressing thing/torquing thing seemed like too much work to me. And, they did the job right. I just dropped it off and picked it up...less $450....of course.
Old 12-29-2004, 05:14 AM
  #32
jtm994's Avatar
yeah mine ran me $455 at a local shop here in town. they are pretty good and can trust them. but i took it back to them yesterday and they fixed the problem in about an hour.
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
colasurdo
07-16-2015 11:32 AM
Iceman4193
07-15-2015 04:48 PM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: rear axel seal i think?
