rear axel bearing?
rear axel bearing?
Im almost possitive my driver side rear axel bearing is shot. Tommarrow Im going to pull the axel and check things out. My question is do you need a press to get these bearings on and off??
I have a 99 4runner
Thanks
I have a 99 4runner
Thanks
Yes you'll need access to a press.
The "Lock collar" which holds the bearing on the axle is pressed off and pressed back on after the bearing has been replacd.
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
