RB/BL Help me decide 1in or 2in?
Ok Rondo, you're on the clock, I've got my 2" kit on its way to me. I went with the grade 8 hardware and ultimate blocks just to be on the safe side. If I would have gone w/1" I probably would have just gone with standard. I don't want to worry about the BL when offroading. Hopefully the gap won't be too much and make my tires look too small, or I'll be forced to get a second set for offroad use $$$$
There will be a large 2" gap .. and your tires will look small
here the solution. click here
Originally Posted by sdastg1
Hey Rob what size tires do you have right now? BTW Im leaning more towards the 1 1/2 inch BL
#25
If you have a TJM bumper up front with a 1" or 2" BL, what did you do about the gap left by the lifted body? Just leave it or is there some sort of Home Depot/Lowes rubber gasket thingy to fill in the gap?
#27
Gap
#28
It will adjust up with a 1" BL leaving around 1/2" to 3/8" gap.
Matched with a nice 1" adjusted rear bumper and fender covers from an early 90's Mini PU you can't even tell it has a BL.
#29
I'm very tempted to go with a 1" BL. My only concern is making it into and out of the garage, esp when lights are added. Currently, I have about 6" clearance between my roof rack and garage door. I'll be adding some Hella 500s, which I think will decrease my clearance to 3". With a 1" BL, I should have 2" of clearance.
I have to keep my 4Runner in the garage during the week since my wife needs her car to commute to work, so her car in the driveway.
#30
Roof rack
#33
My body-lift was already on.
While we are on the subject of bullbars www.4x4connection.com is having a sale on TJM's again it's $379 for a T-17 bull bar just FYI. I got mine from them back when they had them at $377.
#35
#36
#37
Originally Posted by waskillywabbit
Write-Up
2" Roger Brown Body Lift Kit: 2 Bumper brackets, steering extension spacer with 2 longer bolts w/nuts, longer bolts w/lock nuts for spacers, 2" spacers
Now put the bumper back on. Line up the bumper brackets on the front bumper mounts. This is where you need the 2" lift so the bumper will be close to the body again. The mounts on the sides don't line up after you raise the bumper, but I figure if someone hits you up front it won't matter anyway. These just seemed to be for extra support. I just put the bolts back where they came out so in case I need them for something later.
LittleUgly
15
01-02-2020 02:30 PM
scott90
10-04-2015 10:21 AM
hiluxinargentina
09-30-2015 06:51 PM
