R150f Tranny questions
Does anyone know if the bolt patterns for the bellhousing and tcase on the early R150F are the same as the later (95.5 up) R150F.
ie: will the bellhousing and tcase from a 1994 pickup bolt onto a tranny from a 95.5+ tacoma or 4runner.
I know the input shaft is a different length. I'm running a 3.4 in my truck so that should be a non-issue.
Thanks.
Thanks.
um, if you put an early bellhousing on a late transmission, your input shaft is going to be sticknig too far into your motor isn't it? The bellhousings are more or less the same, but the newer ones account for the extra inch or so of input shaft length don't they?
Tonetrk
08-06-2015 10:06 AM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
