quick question
Old 02-11-2004 | 02:20 PM
joeal's Avatar
quick question
how do i tell if there is spark coming from the spark plug wire?
Old 02-11-2004 | 02:23 PM
MTL_4runner's Avatar
Pull the sparkplug wire, put a sparkplug in it, hold it to ground (ie the engine block) and crank over the motor.
Make sure to always have it grounded when cranking....that is very high voltage!!!
Old 02-11-2004 | 02:26 PM
toy283's Avatar
A couple ways. If you have a timing light you can hook the inductive pickup to each wire and watch for flashing. A more effective way is to pull each plug one at a time and ground the casing to the head (just touch it to the outside of the head with an insulated pair of pliers and gloves). Then have a buddy turn over the engine and watch for spark. Don't do this for long, just a few seconds. With practice, you can determine strength of spark as well, something that the timing light method won't tell you.
jasonty
41
12-23-2018 02:00 PM
thefishguy77
08-09-2015 05:15 PM
makemusic116
08-02-2015 06:23 PM
makemusic116
08-02-2015 05:40 AM
icentropy
07-14-2015 11:23 AM
