Question about 2.4 liter
Old 01-05-2007 | 05:14 AM
mtrdrms's Avatar
Well I have developed quite a leak lately in my tacoma. It first appeared to be coming from the oil pan gasket but I replaced that and nothing has changed. Now it looks like it is coming from the aluminum oil filter adapter that bolts to the block. Is there a gasket between this and the block? Has anyone had this problem? It is leaking a drip every 5 minutes or so so it needs to be addressed. Thanks
Andy
Old 01-05-2007 | 05:18 AM
19RUNNER86's Avatar
yeah i think there is a gasket in there. call your local dealer and they should be able to help you out cheaply.
Old 01-05-2007 | 07:19 AM
mtrdrms's Avatar
The bolt that I took out is huge and it has holes in it like a banjo bolt. Does that mean it has to be oriented a certain way upon installation? Or should I just tighten it up?
Old 01-05-2007 | 07:32 AM
19RUNNER86's Avatar
if you can find a service manual check for torque if not you could fudge it...but def dont lose the copper gasket.
Old 01-05-2007 | 08:44 AM
mtrdrms's Avatar
Good call. It looks like that is where the leak was coming from but I'm putting it back together now so we will see.
the1998sr5
15
07-14-2020 09:35 PM
Swim
9
01-04-2016 11:47 AM
coleypull15
11-03-2015 08:41 AM
tobylab
Diesel Swaps
07-17-2015 07:51 PM
Cplmike
07-08-2015 09:47 PM
