Putting Taco Diff lock in 4runner.
I am putting the "RR Diff Lock" ecu and switch from a Tacoma ( I know it is a taco's because the part number is ""35060 instead of ""35070) into a 1998 ltd 4runner. the ecu to my 4runner was removed, along with the switch. Long story short I have the locker installed minus the ecu and switch.
Anyways, the wires coming out of the ecu (remember it is for a taco) do not match the internal wires coming out of my rig. Here are some pictures:
The wires coming out of the ecu:
and the wires coming out of my 4runner:
as you can see, the wires do not match up.
My question is:
what wires need to be matched with what wires?
Is there possibly a schematic or coloring chart I can follow to make sure that the correct ones are matched?
I am also doing the grey wire mod. There is a a grey wire on the ecu, and obviously no grey wire coming out of the car. For this, I will ground the red/blue wire, and tape off the grey wire from the ecu, correct?
thanks for your help in advance.
My question is:
the only thing I can think of is to get a hanes (or eqiv.) manual for both and do some comparing between the wiring diagrams in the two manuals...or maybe someone makes a wiring harness connector to do exactly what your trying to do...
Maybe give Inchworm Gear a call, they specialize in that stuff...
http://www.inchwormgear.com/store/index.php?cPath=25_62
Brian2sun, I will give inchworm a call, or maybe just buy the harness from them.
thanks guys
is it possible for anyone to just take a look at the ecu for a 4runner, and maybe just read off the pin # and the color matched to it? then i can match those colors to the pin # on the ecu i got.
well actually that site gave me the perfect diagram for tacomas, but not the 4runner. all the ones i found for the 4runner were either empty links, or were for 2002+ 4runners, so i couldnt find wiring for the rear, only center.
i did however find another link. i think i have dug around enough to get the right idea.
jerusry
10-19-2015 05:28 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
