Pulls to right
Pulls to right
Ok,here's the deal,I had new tires put on and I also had an alignment done and everything was good.I had it at the shop for a no start problem while I went to Oregon on vacation.When I got it back it pulled to the right so I took it back to the alignment shop and they said it was way out of adjustment.They aligned it again and it still pulled to the right.They put it back on the machine and it says it's all good,they even had their machine recalibrated.It still pulls to the right.The brakes aren't binding.As soon as I let off the brake(speedo not even registering)The wheel turns and it starts moving to the right.What else should I check?Oh yeah,it's my 91 runner.
Well alignments are done with a positive camber to offset the road crown but I dont understand why it would pull so much to the right. Since it doesnt do it when hitting the brakes then thats ruled out. Maybe check the condition of the tires, which they shouldve already done during PAI.
The tires are new,maybe 1500 miles.The tech said all the steering components looked good.They rotated the tires too to see if that would help but it didn't.
a bent rim would cuase a vibration, not a pull unless it was so severly bent that it is really visible and i mean marked bent......
i used to do alignments... how was the caster reading? even if its not in spec, have them bump down the left caster or bump up the right caster so the right side is higher .5* half a degree..... this should almost cure the pull, its hard to tell whats wrong though trying to describe something online
Blamalam
03-12-2022 08:34 AM
Poncho0206
07-10-2015 07:21 PM
