prewired for elocker
Old 05-01-2014 | 08:39 PM
joevanvliet's Avatar
Hey all,
I bought an elocker rear end to put in my non-locking 98 4runner, and am planning to use the factory 4wd computer and rr diff lock switch.
It looks like I'm pre-wired for the computer under the kick panel, but I can't see any signs of a wiring harness to plug the actuator into underneath the truck.
Anyone have any thoughts on where this might be hidden?
Thanks!
Old 05-01-2014 | 08:53 PM
HighLux's Avatar
It doesnt work like that....you need harness from donor truck. Toyota doesnt give you harnesses often if you dont have the option.
Old 05-01-2014 | 09:12 PM
nvm i found a great webpage that explains my next step
http://sonoransteel.com/phong/retrof...ic_locker.html
Old 05-01-2014 | 09:17 PM
HighLux's Avatar
There are a couple guys on here with thread too about building your own switch and relays etc....guys that are like electrical engineer gurus.
The site search button kinda blows.
Best way to harvest info from Yotatech is to go a google search like "e-locker harness build yotatech" resulted in....
https://www.yotatech.com/forums/f105...switch-238775/
Old 05-01-2014 | 09:20 PM
HighLux's Avatar
https://www.google.com/#q=e-locker+h...build+yotatech
All kinds of info boss.
Old 05-03-2014 | 06:09 PM
Jomoka's Avatar
We just put a locker on my wife's 96. No sign at all of any locker prewiring anywhere.
Another thing to look out for is that most (all) non-locker diffs were 4.10 ratio, and most locker diffs are 4.30. So you'll need to swap the front diff too.
Old 05-03-2014 | 06:14 PM
HighLux's Avatar
Thats good info...thanks man. Im in Ofallon MO. Good to see a local guy!
Old 05-03-2014 | 06:15 PM
HighLux's Avatar
I bet you are Hab's hubby?
Old 05-09-2014 | 09:33 AM
Jomoka's Avatar
I am indeed.
She's about got it wired up now.
I'd help, but she shoos me away from working on her truck. So the 'we' I used above is more of a 'royal we'. The most I've done so far is spot the ad for the locker axle on Craigslist. Oh, and pull a 4.30 front diff at the pick-n-pull.
digitalracer
05-16-2016 04:57 AM
Peevedkitten
11
08-31-2015 07:57 PM
mtb_taco
08-20-2015 01:16 PM
digitalracer
08-17-2015 07:01 PM
arjan
05-11-2004 07:32 AM
