pp springs worth it for a 99?
Old 02-12-2007, 12:26 PM
alexe's Avatar
Originally Posted by RR DIFF LOCK
Hey, I like the 240SX fastback in the background. A drift project in progress?
believe it or not im not really into the drifting. i do it every now and then for fun but the car is for grip driving.
so far its got an sr20 2.0L turbo with a t28, apexi power fc standalone engine management, adjustable coil overs, adjustable sways, 17x9" gram lights and lots of other good stuff. its a money pit but i have lots of fun with it so its all worth it
Old 02-12-2007, 12:28 PM
alexe's Avatar
well i just took some measurements from my runner and looks like the pp coils wont get me that much lift. i think i'd be better off saving up for an SS#7. i'll drive it like this till i need new tires then ill do the lift and 33's.
Old 02-12-2007, 02:41 PM
MTL_4runner's Avatar
Originally Posted by X-AWDriver
The better place to measure from is the center of you wheel hub to the flare lip which takes out tire size altogether and possible tire pressure differences.
I don't agree with that because it's hard to say exactly where the center of the hub actually is and when we're talking about accuracy around maybe 1/4", you'll be alot more repeatable measurements going fender to ground than fender to hub (since you have defined points on both sides of the measurement with fender to ground). The other issue is that there are alot of different starting ride heights depending on the year and most people get very confused as people start talking about how much lift they got and measuring ride height cuts through alot of that confusion. The tire size is easy to account for and tire pressure is negligible as well (since most run their tires over 30 psi for highway use anyway). I myself much prefer the fender to ground ride height measurement for comparison purposes.
punks_is_4x4
05-31-2016 06:03 AM
Scottcrb
03-03-2016 11:57 AM
RickyD
10-02-2015 07:53 AM
kcaudill
09-11-2015 02:49 PM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: pp springs worth it for a 99?
