Power Antenna mod - mini write up
Old 06-16-2005 | 08:04 PM
fiveofeen's Avatar
Well my power antenna was broken and I wasnt about to get another. The whip was a choice, but I decided to go cheap.
I purchased a cheap retractable antenna from an auto parts store.
I removed the power antenna unit by removing the inner wheel cover.
I then cut the slotted piece off power antenna tube and used a strong glue and attached it to the aftermarket antenna. You can see the part where the tube it cut its sitting next to the tire.
The purpose of doing this of course is to allow the factory antenna mount to still be used on the fender.
Antenna up
Antenna down
Its a real easy task, and took maybe 30 minutes.
Old 06-18-2005 | 08:07 PM
Keggo's Avatar
Nice! I went a really cheap way and just bought a rubber antenna. But it sticks out to the side... DOH!
Old 06-18-2005 | 08:20 PM
tulsa_97SR5's Avatar
Hey, thanks for posting this up. It may be on my list to do tomorrow, as my non-functioning antenna got bent off roading today. Being able to put it down when needed is a big plus.
Old 04-15-2009 | 09:21 AM
alteredvision's Avatar
Why doesn't anyone use the in-glass FM diversity antenna that is in the back passenger window?
Old 04-15-2009 | 09:33 AM
DeathCougar's Avatar
IIRC those use a smaller than normal plug, so plugging that antenna into a factory deck requires changing that plug, something most don't know how to do.
Old 04-15-2009 | 09:34 AM
scuba's Avatar
Why did you bring up a 4 YEAR OLD THREAD !??!?!?!
HOLY CRAP !!!
Old 04-15-2009 | 09:41 AM
DeathCougar - I have found another post from a guy that goes into more detail on this. Thanks for your response. Why you can not use the FM antenna in the window.
scuba - Because the tread is not locked and the fact that anytime anyone starts a new one they get told to search. I searched it put me into this thread and I posted. Also if I change the topic on a 4 year old thread then no one is going to mind to much and the information comes up in the search.
Old 04-15-2009 | 11:11 AM
We do appreciate the searching. It makes for much less clutter. Scuba is just a mean old miser
Old 04-25-2009 | 05:23 PM
I have found at Autozone a converter to go from the antenna cable that is in the back window into the after market radio that I have. I can not use 2 antennas but can use the built in one that is in the window that I wanted to use instead of the other ones any way. Oh yeah and it cost me $6.00
Part number is on the box just plug into radio and into the cable.
Old 05-02-2009 | 10:48 AM
fireball's Avatar
HOLY CRAP !!!
Sometimes you can't win. Get yelled out for not using the SEARCH feature when posting a new thread, and now you get yelled at for searching and bringing up an old thread with still useful information....
Old 05-04-2009 | 09:42 AM
Well don't listen to Scuba, he's just jealous he didn't think of bringing up an old thread
Old 09-27-2009 | 09:11 PM
luxdlx's Avatar
So, does it work as well?
80Truck
07-24-2015 04:12 PM
Massmayhem247
07-18-2015 06:46 AM
crashburnoveride
07-10-2015 07:39 AM
Edionne13
07-09-2015 02:59 PM
Nickdigg
07-07-2015 07:04 AM
