Poor man's 4runner antenna mod.
Well, i called around my town on a non motorized antenna for my rig and they all told me 42bucks plus tax and it had to be ordered.
So my tight-wad self went over to AUTOZONE AND PEP BOYS and was erked at how the stealership can charge 42 bucks and autozone only 6.99 for the whole set up with a stainless antenna.
The computer showed this for the replacement. So i bought it and installed in a flash. Not gay lookin' either it look pretty damn good and solid too. Will post pics tomorrow. Reception is just as good as the power antenna.
I also bought a flexible rubber antenna(i like the looks of this better also) that screws into it for 3.99 on sale in case the wonderful wife decides to run it thru the carwash again like she did on my power antenna rendering it useless. You can't count on them to unscrew the antenna much less keep em' full of fuel.
Here it is fellas finally downloaded the pics. to my tightwad poormans tacoma wannabee 4runner antenna mod.
Just say no to stealerships.
Autozone: antenna assembly AW-UT91 narrow antenna $6.99 includes stainless antenna whip.
rubber antenna AW-RM1R rubber antenna $3.99
See what ya think.
http://community.webshots.com/user/jonybeck101
See what ya think.
Pix are good ...
Also, what about the installation? When my power antenna went belly-up, I tried replacing it with a stick antenna. However, as I attempted to trace the coax back to the radio, I became discouraged as I saw that I was going to have to disassemble the entire dash just to plug in the antenna cable!
So, being the rocket scientist that I am, I just whacked off the old antenna cable and spliced it to the new antenna cable (not realizing what CRAPPY reception I would then have.)
Consequently, I can now pick up two stations on my radio.
Now I'm looking for a good write-up on how to tear apart a Gen3 dash to replace the antenna ...
http://www.4runners.org/articles/whip/
Took myself and a friend about an hour. I had the exterior done before he had the coax removed from behind the dash. Don't remember my comments on the part # and price. THink i paid 37$ for antenna mast and mounting bracket from the local stealership.
BTW< thanks Bob.
BTW< thanks Bob.
Not hard
Originally posted by VF84Tomcat
Pix are good ...
Pix are good ...
http://www.drawhorn.org/tacoma_whip_antenna.htm
Antunna
I've got mine from Crutchfiled for around $10 and they work fine. When I was there I've ordered the MP3 and some speakers for the front and the back.
The front one didn't fit and the rear one are pain to replace, so I sent the speakers back. Just yesterday I've blow the front/right speakers out.
:pat:
:pat:
Re: Poor man's 4runner antenna mod.
Originally posted by CUBERA
... in case the wonderful wife decides to run it thru the carwash again like she did on my power antenna rendering it useless. You can't count on them to unscrew the antenna much less keep em' full of fuel.
Pix are good ...
Pix are good ...
1. Pull the fender liner back (and remove the wheel if you are able - easier clearance)
2. Cut the antenna cable at the antenna and tape the connector end of the new cable to it.
3. Drop the lower right side of your dash including the glove box. If you can't reach the back of the radio, you'll need to pull that trim piece also (along with whatever else needs to come off to get to that)
4. Gently pull the old cable into the rig which will become the new. Be sure to tape the new cable "IN LINE" with the old, not parallel or any other way that would create a big knot that would make pulling the cable difficult.
Good Luck!
I am not with it fellas. I took the digital pictures but left the wire to download the pics. at a freinds house and they're now in bed.
I will download them tomorrow fer sure. Sorry!
But i do have the model #'s and they are:
(So, being the rocket scientist that I am, I just whacked off the old antenna cable and spliced it to the new antenna cable (not realizing what CRAPPY reception I would then have.)
It's not too late dude. Go to RADIO SHAK and ask for a RG-58 cable wire couplere and connector to connect the 2 wires. I did this on my pick up and had no problems with reception if wires are stripped back carefully aand properly
Thank You Forum!!!
Thank you folks for good posts like these. I also went to Autozone and bought the $7.99 fixed antenna part and did the repair over this weekend. It looks great and works great. THANK YOU for saving me a lot of $$$.
I am trying your mod, but am having tremendous trouble getting the wheel liner off given that I have a fender flares to deal with. I have an '02 SR5 4WD. Any suggestions at getting the stupid wheel liner off?
Thanks,
Danny
Thanks,
Danny
Thanks,
Danny
Thanks,
Danny
Good luck!
So what did you do with the old wiring from the power antenna thats outside behind the fender? I was going down the road one day and my antenna just ejects itself to death on the road. I went back and picked it up and took the plastic track stuff off and just stuck it back in to get reception. Later I noticed the antenna motor was running for quite a while on start up so I just unplugged it from behind the fender and taped it up. Did you guys do the same?
antenna's and radio are over rated. i broke my antenna off a month ago going thru a mud bog and snapped it on a tree branch! as long as you have a couple hundred cd's and a cd changer your good to go!
plus i think the antenna was causing drag thru the air, so now my 22re has a added hp gain of roughly .75 hp!
Originally Posted by <96 Runner>
you have to go through and unclip (ruin) each plastic push-in deal. I would definitely pick some up from the dealer because you WILL break them.
